Hi guys. Bit of advise if poss. Wife bought a 2007 BMW 118i one series last June. Car had full not on purchase. Forward one year on and three thousand miles later. Car failed not on emissions!! Did'nt have lambda or exhaust temp sensor fitted and has wrecked front cat resulting in a 2k bill to get the most ticket. Now my garage bloke reckons that the damage to the sensors etc has been done over at least the last 2 yrs. Car should never have passed not last time. So any ideas how I can take action against dealer/not tester. I think I am struggling but fancy being annoying but don't want to punch anyone. Cheers R
Sounds like whoever fitted the stainless exhaust, also had the ECU remapped, as a missing sensor should trigger a warning light very quickly. You'll most likely find the 'catalyst' has never had a core in it since the exhaust was fitted and the remap done, especially if there's never been a lambda sensor fitted. And even simply fitting the parts likely won't do you any good, as depending on how the ECU has been remapped, the sensors will just be ignored.
However as I've already said, you'd need to prove the bits were missing at the time of test/sale. Although you know you never altered the car, how can prove you've never altered it?
+1 Let VOSA know regardless just in case others have reported the same garage / tester.
Think long and hard about legal action. It's time consuming, frustrating and impacts on your quality of life. The court system in case's such as this are not a panacea for all ills - even if you hold strong evidence. A savvy defendant (especially a car dealer) who has been through the court system can stall, hinder and frustrate the case to draw it out.
You'll find several similar small claims cases for reference on the many consumer, legal forums: most end up being won, but at a cost to the appellant in time and frustration.
I had an issue with a factory fresh new car with less than 5 miles on the clock, to reject it was a nightmare.
Cutting your losses may be your best bet.
