Help me decide - which drive on my Nano?
TimmyOTimmyO Frets: 7613
edited July 2016 in FX
So, Operation:Guitar Gear Into Storage is commencing (decluttering to put house on market) .
 I'm keeping one guitar and a PT Nano at home. On that PT Nano I will have:
Crybaby Mini
SD Vapor Trail delay
Mooer Chorus (only standalone mod I have left since going H9 on the big board - doh)
So room for one drive pedal. I don't mind removing one from the big board for this so I have the following to choose from:
Muffroom Cloud
Peacekeeper
Guv'nor
SD-1
Klone
Prince of Tone clone (unreliable - needs fixing/rehousing)
Carpe Diem
EP Boost
I'd like to be able to play this at a jam night so assume I don't have control over the amp (which may rule out the SD-1 as imho it sounds a bit pants in to a very clean amp) Which way would you go and why?
Also, I'm considering a mod pedal but thing is I like occasional use of different things - what's out there that might work? (bear in mind size matters).
Ta
Tim
Red ones are better.
  • cbellangacbellanga Frets: 572
    put the cry baby mini on the floor and now you can fit 2 drives ;)
    Sd1
  • JalapenoJalapeno Frets: 6402
    Xotic EP
    Feedback
  • TimmyOTimmyO Frets: 7613
    I've decided/promised it'll all pack away in to the Mono Vertigo & Tick, so needs to fit on the Nano.
    Peacekeeper for me but then I'm not a high-gainer.
    It also seems to be quite a versatile pedal.
  • Jimbro66Jimbro66 Frets: 2431
    Treat yourself to a Warthog which will do much of what all those other pedals do and sound good with most amps.
    edited July 2016
    Problem solved by ditching chorus !
    Will get those stuck down properly and tidied up
    0reaction image LOL 2reaction image Wow! 2reaction image Wisdom
  • Wisdom awarded!
  • ThePrettyDamnedThePrettyDamned Frets: 7503
    edited July 2016
    Store (edit) them all and get a rat.
    That'll do anything you like into pretty much any amp :)
