Anyway...fantastic-sounding delay, with more features than I could ever use. My problems with it were:
1 - No way to directly select a preset (to get to the previous one, you have to scroll through all the other three presets *and* the current control settings). This is very awkward in the middle of a song, particularly as it cuts the delay trails off when you switch presets.
2 - It requires 9V AC power, not DC, at 1200mA. That basically means that you won't find a single pedalboard power supply which can do that job and the 9V DC that all your other pedals will need; it's a royal pain in the ass and makes a mess of your board.
After a while, I found I was perfectly willing to ditch all the extra features just to fix these issues, so I got a Flashback X4 instead (which then came with its own set of issues - for example, switching presets cut off the delay repeats, but switching a preset off and then switching the next one on didn't...thus defeating the point of having single-touch access).
Just FYI, I believe the Timebender is discontinued too, which is another good reason you won't see many.
Also, I'm not sure how you had a problem, given that there's a mix control right there?
