I have a hard acoustic case I bought 2nd hand for my Epi EJ200CE which it does not fit,
If you want I can send you the dimensions to see if it will work for you.
£25 and postage if it is any use.
Vintage Toyogakki Hardcase.
Case measurements :-</span>
Overall length 108 cm internal, 110.5 cm external)
Overall depth 15 cm internal (12 cm in bottom + 3 cm in lid) – (External 16.5 cm, 12.5 cm 4 cm lid respectively)
Upper bout 35 cm (37 cm external)
Lower bout 44 cm (46 cm external)
Around five tears in the tolex covering (one larger one, the rest fairly small)
Around 5 marks left from stickers (all fairly large but can be steamed off)
The black binding has come off the lid but is in case pocket, it presses back in nicely and should be an easy fix with some glue.
Toyogakki JAPAN stamped on case latches.
Three latches and handle all working.
The foam and felt lining inside is all in good condition.
The case is structurally sound and should last many more years.
Link to photos warts and all.
http://s1095.photobucket.com/user/johnnyurq/media/Acoustic%20Case/EBay6_zps42797aaa.jpg.html?sort=3&o=0
If you need any specific ones let me know and i can sort others out.Will be out and about for a few hours so will be incommunicado for a while.
No worries if it is not for you, but hopefully it will be and help clear a space for a case that does fit my Epi.
