11 hole used and faintly yellowed Strat scratch plate
8 hole HSS Squier Strat scratch plate
Two Squier engraved neck plates both used wirh matching screws
7 assorted Strat trem covers
New Gotoh Strat jack plate
Used Squier Strat jack plate
Strat trem bridge with 2 sets of claws and springs and screws … has had light use … slim block and beefy cast saddles … not sure if Squier or Mex Fender with a nicely snug fitting arm.
New far eastern LP tailpiece and bridge … spare pair of bridge studs. One pair of body bushings don’t match the bridge as they are ‘black chrome’.
Set of single pin fixing Squier machine heads … these are the deluxe really smooth ones (six on one side).
Pair of used, curve bottom bucker rings in black
Four sets of new white Strat knobs. A buttery couloured set, a used just off white set … and three really yellowed and worn ones.
Three used black Gibbo style hatbox knobs
Three Strat trem tips … relic used.
Pair of Epiphone high output humbuckers 12.26k neck, 15.57k bridge
Ibanez chrome covered bridge humbucker 16.86k (ceramic)
Two nickel tele neck pickup covers … new … but each with a
broken off lug … the Mojo ones are quite brittle. They can still be fitted of
course … but I can’t sell em on new pickups.
Two brass tele neck covers … one a relic.
£65 the lot inc postage ... or split
Three band active bass preamp with blend pot between pickups and battery box ... new £13 inc post
intended to use it on my precision copy ... never got round to it. Not the most super quality in the pots ... so would suit experimenters.
Set of relic Strat saddles, fender stamped £12 inc postage
More stuff to be put up shortly.
