That's an excellent amp - from the mid-1980s, and built as well as a JCM800 valve amp with a proper welded-box steel chassis, plywood cabinet, and over-spec components.
...though sadly, not worth as much as it probably should be due to being 'transistor'. That one also has the less-desirable McKenzie speaker rather than the better Celestion that some came with, although it's easy to change. (An 8-ohm speaker works fine even though the original is 4-ohm, and then allows you to fit an extension speaker jack if you want to - you won't notice a loss of volume with a decent 8-ohm Celestion since the McKenzie isn't all that sensitive.) The mismatching knob is easy to replace, Marshall sell them in sets - probably best to replace all six since the gold cap colour is slightly different now.
(Info for possible buyers
They sound pretty good, not quite like a valve Marshall but not too far off, and take pedals really well.
After all that, the bad news is that it's not worth more than about £100 to maybe £150 absolutely tops given the slightly less than perfect condition (although the rip in the vinyl is easy to stick down if you're careful), the knob and the speaker. Hopefully that's not too unwelcome.
The good news is that there are quite a few of us who like these old solid-state Marshalls, and it shouldn't be too hard to find someone interested. Not me, I'm too far away and I don't really need another one anyway!
You're probably best to post a new thread in the classifieds with a definite price and whether you're willing to ship it, etc.
Hope that helps!
PS, your best plan is to keep it and buy a guitar
The 5210 is almost as good, although again the ones with the McKenzie speaker aren't as good as the ones with the Celestion G12M-70 - which is a speaker I normally detest, but sounds really good in these solid-state amps exactly because they have no top or bottom-end so they hide those parts of the solid-state sound
I would like to also say thank you for being so polite and informative, this must be a great forum
