Recommend a soldering iron please.
I need a soldering iron for pickup installation.
I have no idea what wattage I might need or anything. I don't need something I can fix the boiler with, but I don't want a crap one either.
Links would be most welcome!
  • Modulus_AmpsModulus_Amps Frets: 2595
    I have tried a load, I use a Hakko soldering station now, but have had good results with Anteks from Maplin and the likes
    25w minimum, I prefer 40w though and just be quick on the pots
    http://www.maplin.co.uk/p/antex-25w-mains-soldering-iron-fr12n
    You can pick up cheaper ones from iron mongers that work fine too though and are good enough for occasional use.
  • crunchmancrunchman Frets: 11470
    25W might struggle with ground wires on the back of pots.  The back of the pot is a big heatsink.  If you do use a 25W one for that then leave it to get good and hot before you use it.  If you get a bigger tip that can store more heat it would help.
    I have three different soldering irons.  I've got an Antex 18W I use for building pedals and a couple of beefier ones.  I normally use a 40W one for soldering to the back of pots.
  • guitarfishbayguitarfishbay Frets: 7963
    edited August 2016
    I've been using this one.
    http://www.maplin.co.uk/p/48w-mains-solder-station-n34fb
    It is the only one I've owned, and I'm not especially advanced at soldering.  But it seems to work fine.  The most complex bit of soldering I've done to a pot is wiring up a single humbucker strat from scratch with push/pull pot for coil split (so also did the trem claw ground and output jack).  It has worked x2 (tried two different pickups in the spot), so I must be doing it fast enough (e.g. it is hot enough) to not destroy the pot.  As far as I'm concerned that is good enough for what I need to do.
    I also find this solder removal pump quite useful.  It works fine for me, though I'm not sure what a more heavy duty professional use solution would be. http://www.maplin.co.uk/p/maplin-de-solder-pump-n40ch
  • FelineGuitarsFelineGuitars Frets: 11626
    Get an Antex XS25 http://www.antex.co.uk/soldering/precision-range-soldering-irons/xs25/ BUT ...get the #52 big replacement tip that will make soldering to the back of pots way easier as the larger tip stores more heat to transfer quickly without baking the component for too long http://www.antex.co.uk/soldering/replacement-bits/50-bits-for-xs,mlxs/b005260/
  • strtdvstrtdv Frets: 2467
    I use one of these: http://www.maplin.co.uk/p/60w-mains-lcd-solder-station-a55kj
    Every so often Maplin will discount them to £40
  • oafoaf Frets: 300
    https://www.hakko.com/english/products/hakko_fx888d.html
    I think someone said their Italian arm sell them more cheaply than the UK...
  • ChalkyChalky Frets: 6811
    edited August 2016
    I use the Maplin one set at 650F (IIRC) temperature and with lead solder I get a good result every time.
  • NeilMcGNeilMcG Frets: 62
    I was going to suggest a weller TCP 24v/50w like mine, but they are alarmingly expensive these days. That last forever though and all the parts are available to service them.
  • SporkySporky Frets: 28663
    I'd say Weller too. I have two WS51 soldering stations. Utterly dependable, every part available as a spare.
    interesting, I have a weller station that needs a new iron, but I can buy a whole new station cheaper than buying the iron, so have refused.
    I got my Hakko station for $40 dollars...was very chuffed
  • TheMarlinTheMarlin Frets: 7931
    60 watt solder station from Maplin, plus a smaller simple unit for quick and dirty stuff.
  • Emp_FabEmp_Fab Frets: 24429
    If you can afford it, get a Hakko FX888.  They are considered one of the best 'budget' irons among the electronics community.  I paid just shy of £100 for mine.  I bought it from the Italian agent http://www.batterfly.com/shop/hakko_fx-888d
    as the UK one was charging at least 30% more for the same thing.  Be warned though - there are a lot of fakes out there - almost every one on Ebay is a fake.  Buy from a registered dealer if you get one.
    Bloody great iron.  Soldering is fast and effortless - the bit loses almost no heat between joints.  You'll never need another iron.  Buy cheap - buy twice as they say (and swear at every joint you can't solder properly).
    That's a relief, Emp - I saw you'd posted and feared you were going to recommend thermite. ;)
  • bob21bob21 Frets: 170
    Whilst I would recommend a Weller TCP iron, which is what I use, I recognise for the average user, they're expensive - and one of the main features for me, which is the 'leave it on all day' temperature control, is not necessary for most domestic users.
    For a sensible price point, I've always rated the Antex irons - as recommended by @FelineGuitars.. The only thing they struggle with occasionally is pots - but this also makes it easier for the less experienced user not to bake components/jack sockets/insulation etc. You really can't go wrong for the price either!
  • RolandRoland Frets: 8754
    For the occasional solder that most of us do I've found the Antex 25, as recommended above, perfectly adequate.
  • oafoaf Frets: 300
    Should I bin my Hakko now?! ;)
    I find that the oversize bit and maybe silver content solder help a LOT
    I know you have to use lead free in new guitars you are selling but I still have a half a roll of the old style stuff.  I wouldn't want to use it every day but for my occasional use it makes stuff a lot easier than some of the lead free stuff.
  • chrispy108chrispy108 Frets: 2336
    I've got this in a box somewhere if you want to chuck me your address? I've never used it as I got bought a solderin station at the same time.
    https://www.amazon.co.uk/gp/product/B000ELJ0C4?colid=IT409TDZC3UF&coliid=I1FOQ51TEZ7GTY&psc=1&ref_=wl_it_dp_o_pC_nS_ttl
    If it is just for your own use don't use lead free solder, it is probably worse for you to use in terms of results and fumes from the flux....
