Good morning fellas,
Im just wondering if any of you guys have owned/spent time with the Hughes & Kettner Tubemeister series?
I have just sold my Blackstar HT5RS mini-stack, and am really interested in the Tubemeister series. I will be buying the Tubemeister 112 cab (which is loaded with a V30). The most of the time I play clean, then probably about 25% of the time I play metal (think iron maiden/black label society/megadeth.... nothing too br00tal).
Is there much difference between the 18watt head and the 36watt head in terms of tone?
What are your thoughts and opinions on these amps? Any help would be highly apprieciated
I originally bought it to replace my Hayden 30W Mofo head but it couldn't quite cut the mustard for me so I moved it on.
I found that I needed to tweak it quite a bit to get it to where I'm happy with it though, as it was a bit tizzy at low volume and there's a horrible mid range honk when matched with Celestion V30 speakers that seem to be fitted to every cab on the market
When I first got it, I liked the sounds but it was just missing something and for want of a better word "a bit polite".
Changing the valves definitely helped, but the big epiphany moment was finally getting rid of the Celestion V30's in my cabs for some Reaper black back G12h clones.
The chain of small tweaks and changes has given me a small guitar rig that absolute roars without being monstrously loud.
There's still a threshold that above everything comes alive but it's much lower than it used to be and I find that I can get lots of lovely inbetween tones by backing of the guitar vol pot.
<○> Big Norm Feedback
As @ICBM knows, I was considering getting a Blackstar ID60 head as backup and for home use... but now I'm also looking into whether a Mesa head or something like the H&K TB18 would do me...
My YouTube Channel
My YouTube Channel
My YouTube Channel
I get the sterile comments on it but if you're using the on board boost, I'd say that was potentially the problem.
The heads don't have reverb, but the combos do.
I have a 18c with the 10'' speaker, good discounts last year as they discontinued the 10'' in favour of the 12''.
Good for home use with the built in power soak going down to 1w![:) :)](/plugins/EmojiExtender/emoji/fb/1.gif)
