Any Mac experts?
TimmyOTimmyO Frets: 7582
anyone got any thoughts on this:?
MBPr with El Capitan.
FileVault was enabled from the get go and all was well.
Suddenly it was not possible to log in - touchpad/mouse/keyboard barely responsive - eventually it gives the option to reboot minus filevault - this fixes the issue (after it spends some time decrypting the disc)
all appears to be well, no data lost. Re-enable FV, reboot, same issue. Disable FV, reboot, all well.
so as long as I don't enable FileVault - everything is fine.
WTF?
Red ones are better.
  • have you gone through repair disk routine yet to see if that helps?
  • beed84beed84 Frets: 2422
    Try PRAM reset:
    1. Turn off mac
    2. Turn on and hold down command, option, p and r
    3. Hold until it reboots
    4. Let go when it chimes and let it load
    Hopefully that will resolve it.
  • digitalscreamdigitalscream Frets: 26810
    Total shot in the dark, but could it be a potential disk problem?
    In any case, the first thing you need to do is boot up without FV and do a full backup if you can.
    <space for hire>
  • JalapenoJalapeno Frets: 6399
    This.
    Feedback
    I would boot into recovery mode and run permissions repair, verify disk etc and try rebooting again with FV on and go from there.
  • TimmyOTimmyO Frets: 7582
    edited August 2016
    Yeah I've got a full bootable image and Time Machine backups on an external drive, I'm all good for backups ;-)
    cheers will try that permissions thing
    tim
    edited August 2016
    FileVault shouldn't really have anything to do with mouse or keyboard performance, and it shouldn't prevent you from logging in.
    You might have a permissions error on your drive, or your drive is about to die on you.
    Also, fixing permissions using Disk Utility can be a bit hit and miss. Much better to do it from within terminal.
  • WhitecatWhitecat Frets: 5452
    I think in El Capitan now you *have* to do it that way, they've removed that option from DU.
    There is no fix permissions option in du or in the recovery mode du
    did the other stuff.
    rebooted
    activated FV
    rebooted - prob was back - unresponsive keyboard so can't log in.
    after a while option to power cycle in to a login issues screen comes up
    do that
    subsequent screen asks for password to disable FV
    type it in
    says pw is wrong (it isn't - try many many times being super careful with typing)
    stuck  I in a loop of the 6 lines above :-(
    edited August 2016
    Load Terminal and type this: sudo diskutil repairPermissions /
    Is it possible to boot in to terminal ?
    Yep, hold down Cmd+S when you restart.
    Ok the next boot let me "reset" my password
    boot cycles now seem to take an age between chime and apple logo
  • Danny1969Danny1969 Frets: 10474
    Did you reset the NVRAM ? if not turn on hold down cmd + option + P + R keep holding until it restarts and you hear it chime a second time
    I think I got 3 chimes when it did that key combo (I wasn't sure how long to hold but held for at least 3 chimes worth lol )
    I'm stuck in a cycle of unresponsive keyboard, reboots to recovery, rejects password to disable FileVault
    Oh wow. That was news to me!
    The terminal command didn't work - seems to have changed - googled for another and ran fix permissions
    Also got a 'partition size error kit prevent boot' message running no first aid in the disk this time.
    fix seems to be to change partition size then change it back, but I couldn't do this in safe mode for some reason (just errors and stopped the process)
    was as about to give up and do fresh OS X install but re-did the pram reset for no particular reason. This time it booted normally - wtf.
    filevault now reports encrypting the drive. Few mins remaining. The next reboot will be the important one...
    Optimizing- 1 hour remaining.
    (looks around empty office)
    3 hours ....
