Me being young and inexperienced, I was talked into recapping which changed it into a hard and sharp sounding amp.
I was gutted and got rid of it.
I ended up buying another one in the mid 00's that had that lovely midrange of my old one.
Problem is I really would like to get rid of the hum.
How exactly doe the hum show itself? If the amp hums with no input and all controls at minimum then yes, likely to be power supply hum, ripple. Could of course be a hummy PI valve? Could be way out of balance power valves (tho fixing that could change the tone as well! Guitar amps can be a comedy of errors. )
If the main HT cap IS borked then you HAVE to get it changed or one day it could spew conductive crap all over the chassis. If you get it done make sure the tech does not slam in a bigger one on the false premise that "more is always better"!
Tricky! You need The Man...IC! I say ICBM!
Dave.
i did another swap out of the preamp valves and managed to reduce it, V2 was noisy. It's not gone completely and is worse when the loop is active. Tried swapping v4 (loop valve) but no alternative valve reduces it.
it seems to be multiple things in the preamp section since when pulling the PI the amp is quiet (im assuming all you hear in this situation is the power valves since they have no input).
That sounds like poor heater lead dressing or maybe the amp does not have a centre tapped heater supply? If it is centre tapped you could try the old dodge of jacking the tap up a few volts, maybe tens of volts positive. If not CT'ed fit a 100 Ohm humdinger pot, you can connect the wiper of that to +ve as well.
None of that is going to do Jack to the basic sound.
Dave.
It's unlikely to be lead dress on a Mesa because the preamps are entirely PCB-built, and the rest of the wiring looms are tightly tied so they can't move - if it didn't hum when it was new it won't be the cause now
Mesa Dual Rec…
Cannot see any twisted heater wires in there IC. Is it perhaps DC heated?
Dave.
Bandcamp
Spotify, Apple et al
Electrolytic capacitors of yesteryear had a vast tolerance. +80 to -20%. Modern caps are better, +- 20% or so therefore you could have an old amp with caps on the lower tolerance and a tech replaces them with THE SAME NOMINNAL VALUE but they are top tolerance and so nearly half as big again!
Now I have NO idea how a 22mfd cap might change the sound/feel of an amp compared to 16mfds but it might! This is just one of a long list of things gitampwise that are waiting for some enterprising U grad to do as a thesis!
A thought occurs? You can fit a bigger, better res' cap but insert some resistance in the rectifier circuit. Best of many, you get lower ripple, less stress on a valve rect and the power traff plus you keep your sag!
Shoot! You could waste yer life messing with these things!
Dave.
Here's mine:
http://forum.grailtone.com/viewtopic.php?f=24&t=52723&sid=7dd58edf11f43ae383b09ff9fcdb5791#p377375
The two small blue caps are the bias filters - don't change those, the hum isn't coming from the power section. The medium-size purple one replacing the smaller original orange/black cap is for the low-voltage power supply for the LDR switching - also not going to be the problem.
All the other orange caps are signal caps and shouldn't be replaced unless the fail (extremely rare).
The R332/R282 change is the other way round according to the schematic - export 50Hz models should have R282 but not R332. I think R282 is the right-hand one of the group of three below and to the right of the R332 space, partly hidden.
Looking at the temperature rating on the preamp filter caps that are right next to two of the power valves is slightly worrying - 65ºC Max. I stuck a thermal probe into my Trem-o-verb once and measured 80º after it had been on for about two hours… that might explain why they're on the way out!
Will this change the sound/feel at all?
You can safely discharge the caps each time by simply turning the power off with the standby still set to 'play' and waiting a minute or two - they will all discharge through the divider resistors on the main cap pair. Leave the standby in 'play' until you're ready to power up again.
Many techs will find this too fussy and would just replace them all and be done with it! But if you're doing it yourself rather than paying someone else and you are really concerned about changing the sound of the amp, it's probably worth doing it the long way. The worst case is that you end up replacing all four anyway.
Up to you of course but I would not bother to go for 105C caps. You might have a problem getting then in. Modern 85C caps are going to last 30 years at least, will we still have/can afford valves by then?
ICBM. You have oft remarked that Blackstar amps are "stiff". I had put this down to the generous filter caps used but then I learn that Mesa uses 220mfds!
Funny old things Amps...Innit!
Dave.
Mesas also seem to have very 'poor' transformer regulation, which I think has a lot to do with it. There's a significant change the the HT voltage when altering the power valve bias - which I know they don't make adjustable normally! But I did
The B's use stacked 220s in the higher power amps. Don't have all the schems in head but for sure the A100 is 2 450V 220s in series (had one in the wrong way round just the once..Messy!) .
The saggy Mesa traff could be the result of running it on 50Hz? Does it get hotter than you would expect?
Dave.
