My point was most people these days are using smaller cabs so it is in theory easy enough to see top controls. If you've got a taller setup, such as a 4x12 raised off the floor in some way (wheels etc) you might start having to lean over to see controls, which is obviously not ideal. Personally I prefer two 4x12s side by side to a full stack anyway
They're OK for very small combos that you're most likely to use at home, or just maybe at a gig where you have a small combo raised up so the controls are then about right, but I can't think of any head that fits either of those.
Admittedly I didn't realise that this is in fact a combo .
It's hardly "the world's first BOSS Amplifier range", though… from the 80s:
http://medias.audiofanzine.com/images/thumbs3/boss-mg-10-guitar-amplifier-469752.jpg
And it doesn't sound like the types of sound it's aimed at have changed much, even though the new ones does actually do them a lot better.
The distorted tones aren't the greatest but they still sound better to my ears than ones of Fender Bassbreaker Series which in the videos I have come across do a fine job of a valve amp producing distorted tones of a bad solid state amp.
The THR10 was dubbed as "the third amp", this is the second and third amp rolled into one.
I don't get why these amps always have: "token clean channel", "channel with more gain than you will use in most non metal gigs", "channel of insane over gained metal", "channel of pure white noise and 15 chained metal zones".
