Any Javascript experts?
A problem doing my head in. I'm using .Net MVC.
In my view I have the following three fields.
<div class="form-group">
            @Html.LabelFor(model => model.Environment, htmlAttributes: new { @class = "control-label col-md-2" })
            <div class="col-md-10">
                @Html.DropDownListFor(model => model.Environment, @ViewBag.EnvironmentList as IEnumerable<SelectListItem>, new { id = "EnvID" })
                @Html.ValidationMessageFor(model => model.Environment, "", new { @class = "text-danger" })
            </div>
        </div> ///This is a drop down
            @Html.LabelFor(model => model.Physical, htmlAttributes: new { @class = "control-label col-md-2" })
                <div class="checkbox">
                    @Html.EditorFor(model => model.Physical, new { htmlAttributes = new { id = "PHYSID" } })
                    @Html.ValidationMessageFor(model => model.Physical, "", new { @class = "text-danger" })
                </div>
            </div>
        </div> //// This is a checkbox
            @Html.LabelFor(model => model.ClusterName, htmlAttributes: new { @class = "control-label col-md-2" })
                @Html.EditorFor(model => model.ClusterName, new { htmlAttributes = new { @class = "form-control", id = "CLUSTERID" } } )
                @Html.ValidationMessageFor(model => model.ClusterName, "", new { @class = "text-danger" })
            </div>
        </div> /// This is a text field
So if the checkbox is unchecked I call a controller view to populate. If the checkbox is checked I just want it to display 'NONE'
My Java script code is.
$('#PHYSID').click(function() {
        var Phys_isChecked = $('#PHYSID').is(':checked');
        var Env_selectedVal = $("#EnvID").val();
        var OPP_SelectedVal = '@(ViewBag.OppID)';
        if (Phys_isChecked = "true") {
            $('#CLUSTERID').val("NONE");
        else {
            $.ajax({
                type: "POST",
                url: "../OPP_Landscape/GetClusterName",
                data: { OPPID: OPP_SelectedVal, ENV: Env_selectedVal },
                cache: false,
                dataType: "json",
                success: function (Cluster) { $('#CLUSTERID').val(Cluster); }
        $('#EnvID').change(function() {
            alert(Env_selectedVal);
            alert(OPP_SelectedVal);
            alert(Phys_isChecked);
            if (Phys_isChecked = 'false') {
                $.ajax({
                    type: "POST",
                    cache: false,
                    dataType: "json",
            }  else if (Phys_isChecked= 'true') {
                alert("Not Checked");
Now the code seems to work, but if I change the checkbox to checked, it fills in the text field with 'None' as expected but if I then change the dropdown it still fills in the textbox even though the if statement is true?
  • RedRabbitRedRabbit Frets: 486
    edited September 2016
    Not an expert by any means but it looks to me as though you are using assignments in your if statements. Probably want to change the single = to double (or, with this being JS, triple just to be safe).
  • If I use double or triple nothing happens?
    I'm not a javascript expert but I thought checking for boolean equality should be something like this?
    if (Phys_isChecked === true) {
    or simply
    if (Phys_isChecked) {
    since you don't need to worry about type-coercion.
  • JalapenoJalapeno Frets: 6399
    Similarly not an expert - but a pedant - use the same comment symbols throughout, you have variable number of "/"
    Feedback
    or simply
    That worked thanks using no = signs.
    Cheers (why can't equals syntax be common across languages)
  • That worked thanks using no = signs.
    The === probably didn't work for you because you had "true" in quotes, which makes it a string not a boolean. Remove the quotes and the === should work as well.
    At first I gave you Wisdom for that, but then decided it was more of a LOL. My preference is to not have comments, the code should be clear enough without them ;-)
    Now that DOES deserve a lol!
    I was being serious though.
