WTB: Cheap combo amp for the workshop.
octatonicoctatonic Frets: 33848
I need a cheap but working amp for the workshop.
Not bothered about brand provided I can plug guitars into it to check electronics are working.
Smaller would be better, probably can't be arsed with tubes, so something solid state would be perfect.
I'd collect but probably need to be under 60 miles or so from OX29.
Definitely under £100- the cheaper the better as it will mostly sit under the bench getting dusty only to be used a couple of times a week.
If you have something you think might work then please let me know.
Cheers.
