Based in Carlisle area. Amp in excellent condition. No cab. £200.
The mod kit has changed the left 8ohm output into a Line Out, suitable for sending a line-level signal to a larger amplifier, P.A. mixing desk etc. The line-out jack signal comes after the output transformer so is rich in output valve as well as preamp valve distortion (speaker must be connected). It was all installed by a proper engineer. I can provide all instructions so you can see precisely what was done!
The blurb says:
"Critical components in the signal path are upgraded to boutique grade items, including Mallory 150M Series capacitors, silver mica capacitors, and carbon composition resistors, for a more authentic vintage valve sound. Output tube bias is corrected to produce maximum power output. What’s more the output valve distortion is noticeably sweeter and less harsh sounding. The rubbish heater connectors are removed and the valve heater circuit wiring is completely hard wired. Lastly, wire dress is fully sorted for minimum noise levels."
My band, Red For Dissent
