In the 7 or so years I've been building effects, I've essentially not made money doing it. If you take into account my time and even my fuel getting to and from Cleggy's (where all the pedal building takes place), I'm way out of pocket even though the pedal fund is a couple of hundred quid in the black at the moment. It's usually the other way around, but that's the sort of area we work in. When it gets a few hundred quid down, we'll have a purge of the pedal mountain. When it's up, we'll get some new stuff built, and on it goes. Works for us, but we long ago abandoned any idea of trying to make it earn us a living.
It's a totally flooded market and I imagine it's even harder to crack now days. I believe even Keeley nearly went bust in the last few years
if your friend wants to do it, he needs to go "all in" and by that I mean every aspect of the business needs constant momentum and pressure, be it the accounts, marketing, social media, circuit design, building etc etc.
I guess the only comparable thing thing is doing a PhD, you've got to really want to do it and be 100% passionate.....
that and and a lot of luck.
Build a proper buffered switching circuit with at the very least, a soft-action metal momentary switch if he can't afford to tool up for a nice casing with the switch integrated or do it some other way.
That will give him a market advantage over almost every other small-builder pedal out there, for a small number of people. It may well put off others, but the market is so flooded now that you want something that makes you stand out not something that makes you follow the herd.
That's the impression I get from the blurb and hype on most 'boutique' sites.
Lots of classic pedals had really, really crap bypasses - they'd switch only the input or the output, meaning that the effect circuit was hanging on the signal line and massively loading it down.
At the same time, Boss's buffered bypass wasn't quite unity gain, so with a handfulof pedals there was an audible difference between going through them (in bypass) and going straight into the amp. Just enough level difference to sound crap without just sounding quieter (it's a brilliant trick for skewing shootouts - make the option you want to win be about 0.5dB louder).
A good buffered bypass does take a bit of designing - there are suprisingly few decent cookbook circuits - and more PCB space and layout time. A good 3PDT (they do exist) is fairly easy to wire up and produces a pretty darned good bypass.
At the start of the boutique goldrush a lot of not-very-talented people were building near clones of commercial pedals, just putting in more expensive components and maybe tweaking a value or two. And often stripping out what they thought were unnecessary bits, like wrappers. Designing a buffered bypass from scratch wasn't going to be easy, so TB got a lot of positive marketing.
And yeah pretty much agreed. I'd say (though it could well be psychological) that I think I can tell a Boss buffer even with just one in the circuit, but certainly with several you can (or with one single much-worse buffer).
I suspect it's because the input impedence to ground on a typical opamp circuit is very high but the output impedence to ground is a lot lower due to the neg feedback path ... so disconnecting the output is less loading when in parallel in bypass mode
Not a pedal expert so happy to be corrected
For example, I think a Muffy fuzz voiced just right with an analog octave up or down running into it - activated by footswitch - would be really useful. 3 knobs - gain, octave amount and master level. Keep it simple, give it bags of character, but make it multi-purpose.
That, or you go the route of the SS/BS Buzzz (one of the best pedals ever) and give it multiple switchable functions - octave on/off, octave up/down, mids scoop/flat, level control bypass for a scary boost - and make them assignable to a second footswitch.
TLDR: more versatile effects with simple controls, more effects with intricate and powerful controls, less of the same three-knob dirt pedals
I
For what it's worth, if you have some vintage half-bypass pedals like this and you don't want to mod them, you can fix the problem very simply with a good buffer in front - even something as simple as a Boss tuner will work.
On another note, the best advice I can give is don't let magazines review your kit. If they return it it'll look like they played football with it. They'll say useful things like "ideal for covering the Rhubarb And Custard theme tune", then say it's too expensive (while giving five stars to a similar but more expensive factory-built pedal on the opposite page).
To cap it all off, if people completely unrelated to you point out that the review was a bit unfair, you'll then get shitty emails from the magazine's editor about how they were doing you a favour, it's the last time they blah blah blah.
Oh, and in my experience if you get a review you'll never sell that model again!
[/grumpy] [/embittered]
Others may have had a better experience or just be less of a princess than me.
I'd also say there is a huge difference between wanting to make pedals and sell them to fund the next lot, and wanting to get to the next level where it's actually a profit-making business. The two are not the same at all.
A small thing but I like the brands that do it.
and wow that sucks about the magazine reviews, sporky.
I totally agree that making a living building small electronics devices is next to impossible. Folks just do not understand the problems of manufacture. They often criticise firms for using a "less than stellar" component but miss the point that the product is usually aimed at and costed for a specific market and a better "widgerdoo" would, A) price it out of that point or,
not be noticed by the target audience or C) be swapped out anway! Or all three!
Then there is Joe Public. I had 30 years of him but NOT as self employed. I went home every night and could get away from his wingeings and moanings. (99.9% of peeps are of course lovely but there is always a few!)
On "True" bypass. Anyone who understands the way good quality studio equipment is connected together understands why TB is a nonsense. I also don't understand the handwringing re signal switching? FETs are very easy to implement. Think of the "effect" as a block of circuitry and the buffers outside of that. FETs are then used to send signals either through the "block" or directly to the output buffer.
Duggy Self's book will tell you all you need to know about FET audio switching!
Dave.
