If pulling the PI stops the noise it doesn't guarantee it's the valve though - it could be something in the PI circuit, or it could even still be a power valve since it could be feeding back via the NFB loop, which removing the PI will break. So if pulling the PI *does* stop it, you then need to try another valve there - if you don't have any spare, use the V1 or V2 valve temporarily.
I have a spare Chinese Ruby 12AX7 but I was seeking tube recommendations for more crunch in V2.
You could possibly mod the amp, if you're into that… possibly by reducing the value of R11, which you can do by paralleling another resistor onto it, you don't have to remove it. Whether that would cause other problems, I don't know.
Or just get a Tube Screamer
I'll try changing the phase inverter again and checking the other tubes but I'm now concerned it may be something more than just tubes.
