The power output of an amplifier is V x I so unless you change one or the other you will get no more power. IF you have 550V available AND you can bias the valves at 50mA each AND the PI can drive them hard enough, sure you could get 100 watts per pair! But can you?
Then, different output valve types need to "see" the optimum load impedance to deliver maximum power. It MIGHT be that a pair of KT88s will be loaded so as to deliver a few more watts but things could just as easily go the other way.
Err? Jusfort? IF you feel you need a solo boost with a 100W amp either IT is well down on power or you are deaf mate. Where are you playing? Hyde park?
Dave.
You probably will also get a chunkier, clearer tone but that may actually make solos cut through less well.
