After scratching a couple of itches, I've realised that as great as these amps are, I've moved on in my expectations in what I want from an amp.
HH IC100S - bought recently from
@simplyben. I've replaced the broken IC socket with a brand new one of the same type. Whilst it was apart, I gave all the pots a squirt with some Servisol. Its all working well, although I *think* the Sustain pot has been replaced at some point with a different value, as it isn't a particularly 'linear' response - it does increase and decrease, so perhaps that's what its supposed to do! The front panel isn't cracked (unusual) and lights up green. It is the amp that Wilko Johnson used with the Feelgoods (although his was a combo - same amp section), ditto Bauhaus and the Wedding Present. Hackett used a similar, although higher spec, amp with early Genesis too... anyway, enough of the sales speil £90 delivered buys this great British amp.
Marshall 5005 Lead 12 combo - bought recently elsewhere to relive my youth. Since I received it, I've given the pots and the input jacks a squirt with the Servisol to stop the scratching. It seems to be working well - and sounds suitably angry when you want it to. Its a great sound, but not one I tend to use these days as I'm a confirmed Fender fan. £90 delivered for this great British amp.
If you can collect from near Kettering, Northants - or daytimes from Bourne, Lincs, then a discount will be given for the postage costs.
Will post pictures later.
(assuming I dont see you before hand)
May consider trades with either or both.
