Seriously tempted by one of these (probably the 100 for the extra channels/presets) as a backup/alternative to my Blackstar 104 head & 2x12 cab setup. Theoretically it could substitute for both the big amp AND the pedalboard for gigs where space is tight, I need to travel light, or need to be in/out a bit quicker than usual...
From what I am reading the K50 will keep up with a lighter drummer but really need 100w for a harder hitter/rocker.
K50 reduces the preset count and doesn't work with the footswitch (which appears to be well sorted).
Also, for anyone comparing the Katana and Blues Cube series, one of the main Boss guy posted on a forum that the Blues Cube is voiced more in line with a 6V6 tube amp whereas the Katana is more like an EL34. The Blues Cube has a plywood case and discrete power amp whereas Katana in MDF and IC based power amp (cheaper)
I ordered a K50 yesterday,should have it in a couple of days,i only use an Amp for gigging(not at home),so i'll post my results,for anyone interested.
