What parts for rewiring my Sheraton.
rlwrlw Frets: 4748
I'm rewiring my Sheraton - first time doing this so I thought I'd start off with something easy -  with new pots, wiring, switch etc.  Pickup are Stormy Mondays acquired here last week.
Question is, what pots should I be buying - recommended make and type - as I don't want to order the wrong bits.  Presumably 500k but beyond that..............?  I will probably go for 50s wiring too, if that makes any difference.
Ta.
  • shugzshugz Frets: 770
    edited January 2017
    If going US/Imperial sized pots then you'll need to open out the holes on your guitar to accommodate these.
    Good CTS or Bourns 500k pots, Sprague OD caps or better/ more expensive ones (yes ICBM the expensive ones sound the same....), Switchcraft switch and jack and use good quality braid throughout. 50s wiring or modern up to you, depends if you like keeping more treble when turning volume down. Use leaded solder as well as ROHS stuff worse than blu-tak.
    I'm making some ES looms later this week, they are a little more complex than a Les Paul harness but fun to do.  Best of luck with your one.
    Cheers
    Hugh
    www.proudhoney.com
  • rlwrlw Frets: 4748
    If you want to make an extra one....................
  • KylefKylef Frets: 1087
    @rlw Shugz has made me two ES looms in the last few weeks, highly recommended.
  • ICBMICBM Frets: 72864
    Added-silver lead-free - which you can buy in Maplins if you need to - is fine, if a bit more expensive. It's just the cheap lead-free - which is little more than plain tin, really - which is crap.
    Thanks @ICBM might get some for a demo. Think the stuff I've used in the past was the cheap horrible stuff....kinda put me off for life! :)
    @rlw if I can help just holler but honestly wasn't trying a hustle. There are fun to do and if you want to give it a go yourself go for it. I'll help with any advice I have as I'm sure other tech types here will as well.
    Cheers
    Hugh
    P.s useless info but cap tested a LOAD of old 50s and 60s caps today. Amazingly zero drift on 95% of them. The ones not in range were very very close. Tried some ODs and whilst still close, nowhere near as tight on the value they were representing. Doesn't make them bad, just learned something myself doing that.
    www.proudhoney.com
    Thanks very much @Kylef really appreciate that. Lovely geetars they went into as well, thanks a lot for the orders.
    Cheers
    Hugh
    www.proudhoney.com
    I have say that I'm not convinced that it's going be fun and I was quite serious about making another one.....
    If i can help just let me know.
    Sent a PM earlier @rlw :)
    Cheers
    Hugh
    www.proudhoney.com
  • shaunmshaunm Frets: 1639
    I came here to suggest you speak to @shugz ;
    im too late
    im too late
    Indeed  :)
    You're likely to run into problems fitting full sized CTS pots through your Sheraton's F holes.
  • FretwiredFretwired Frets: 24602
    Cheers
    Hugh
    I bought a @shugz loom for my Epi Dot - my luthier was impressed. I got some Gibson '57s cheap on eBay and a TonePros bridge. Great guitar now ..
    Thank you @Fretwired glad it's still working out for you. That was a while ago now I think too.
    Think you got a pre-Shugzloomz (RIP) one as well...it'll be worth a cool 24p if you keep it a few more years :)
    Cheers
    Hugh
    www.proudhoney.com
  • paulnb57paulnb57 Frets: 3090
    Ive admitted defeat rewiring an Epi Studio Pro, New pickups and complete rewire, with a second tone, (Studio has single volume and tone) full size CTS pots are a disaster to try and get in, got it all sorted after about two hours of fiddling faffing and swearing, to find no output as the earth on the output socket had broken, during all the manoevering, of course I removed everything to find this.......mini CTS pots are in the mail for round two!
    Can be a fiddly job, sorry to hear it hasnt gone well.
    Cheers
    Hugh
    www.proudhoney.com
    Fiddly? Why on earth there is no rear access is beyond me....Lucille has rear access.....mmmmmm........that sounds pervy.....
    I may be getting the saw out.....
  • TimmyOTimmyO Frets: 7643
    The most traumatic guitar-based thing in my life ever was rewiring a Sheraton.
    I'm not a great solderer/DIYer anyway, and it took me something like 12 hours of stress, sweat and failed attempts. I vowed to only ever pay someone else to do it if I needed to rewire a semi again!
    That said, the results were fantastic - Tonepros bridge and 57 classics and CTS posts and switch - sounded *amazing*
    (but never, ever again)
    Red ones are better.
    I going to start dismantling this weekend so I will see what size pots are in there.   I've a feeling that the new tuners - chrome Grovers - new bridge and tailpiece - Tonespros - and new pups - Stormy Mondays -  will make a huge difference and I'm quite prepared for a a bit of swearing and a bit of grief too.
    I've never rewired a guitar before and haven't soldered anything except my hot water tank for about thirty years but I have a fancy new soldering iron and 64 years of learning patience to fall back on.
    go for it, glad you're giving it a go. If you need any help just let me know.
    They aren't easy jobs but do get better/ easier with practice. Hope it goes well
    Cheers
    Hugh
    www.proudhoney.com
