What parts for rewiring my Sheraton.
  • SteveRobinsonSteveRobinson Frets: 7063
    On the original Sheraton II I have been known to cut away the block on the treble side of the bridge pickup and feed everything through the hole. Modern Gibson ES-335s have no block there for the same reason.
  • rlwrlw Frets: 4730
    Aha............
    Love it. No mercy!
  • shugzshugz Frets: 768
    CTS full size pots will fit through the f-hole on Gibsons. It's close though but those should go through ok. Not 100% on Epis though.
    Cheers
    Hugh
    www.proudhoney.com
  • thermionicthermionic Frets: 9671
    There's a wide variation in Epi f-holes if you look at a few photos. My old Sheraton had quite svelte ones, later ones look to be a little cruder-looking in comparison (wider).
  • paulnb57paulnb57 Frets: 3058
    Success this afternoon on my 335 Studio dot and it all works! Much, much easier with CTS mini pots, full size fit through the f holes at the widest point, but minis made it a doddle, still took me a couple of hours to solder it all up and installl, what made a huge difference was making a cardboard replocal of the hole spacing on the guitar to get the wire runs right, then I only had to solder the pick up and bridge earth wires with the whole mess resting on top if the guitar....
    I'm hoping that my Sheraton has the more capacious f-holes having ordered full size CTS pots.
    Still figuring out how to trim the wires to length once it's all in though.
    What wires? Sorry not trying to be a smart Alec I'm just curious. My advice would be to work off-board using a template then install.
    I make my looms like this these days and the fit/ go in well:
    http://i.imgur.com/E83KwSx.jpg
    Good luck :)
    Cheers
    Hugh
    www.proudhoney.com
  • CorvusCorvus Frets: 2932
    CTS went in my Dot, bit of a squeeze but went in OK. As ^ I made a sort of cardboard box that sat above the positions so I could get the lengths sorted right. Wish mine was as neat s Hughs! First time around is slow, easy after that. Tubing & jack dowel on wire for the fishing.
    I did the same as shugz with the template, made life soo much easier......
  • rossirossi Frets: 1705
    If its any help to anyone I made gradual upgrades to my Dot  SE as follows .Gotoh stop tail .I then restrung it and played it .sounded a bit more resonant . Tonerider Rocksongs nickel covered pickups  wired by cut and join .Great improvement .Gotoh bridge .A bit more resonance .Grover deluxe tuners  .These added a lot more resonance than I imagined they would ,Still kept the  same strings on .A complete fret level and neck adjustment  while keeping same strings followed by a nut job .The guitar now played like a Gibson  335 I tried at the same time as the Epi rather than an Epiphone ..When a wire fell off the switch  I finally rewired it using  CTS pots and orange drops.i later sold it .I was surprised just how much more sound depth came from the bridge ,tail piece and  tuners.I kept the same strings on to keep a constant .The Rocksongs transformed the sound and the fret level and string height transformed it splayability .
    In other words I just kept the wooden bit.................
