New empress dual delay
TeetonetalTeetonetal Frets: 7816
1) It's stereo
2) It can go backwards through presets
3) You can choose exactly how many presets you want
4) It can do buffered bypass so you get trails
5) It's SD card updatable like the Reverb, so you get new modes as we come up with them. We've done pretty well so far of adding features to the Reverb that people voted for in our voting forum.
6) When we release the looper for the Reverb, we'll release it for the Echosystem as well. It will be separate from the delay section, unlike on the Superdelay, where it was a mode. So you can loop and delay at the same time
7) Lot more presets, forget the exact number
8) It's dual engine, so you can have twocompletely independent delays. Or you can sync the delay times of the two engines insome neat ratio.
9) Soft touch switches which are less noisy and much less prone to breaking.
10) We have a lot more processing power than on the Superdelay, so we don't have that restriction when doing emulations
11) It has a control port which takes expression pedal, cv, external switch, or midi (you need a midibox or a Disaster Area multijack)
«13
