It doesn't actually matter all that much since the amps should be fused correctly. The plug fuse is just to prevent the cable burning in the event of a catastrophic short/failure.
R.
Eqd Speaker Cranker clone
This matter comes up in music related forums all the time and the basic answer is, don't really matter.
Now I doubt anyone is more OCD than I when it comes to electrical safety but the fact is that even a wimpy, 5 amp 2 core lamp cable is easily capable of carrying the fusing current of a 13A fuse (if you had 15mtrs of it under a carpet, maybe not but ordinarily, yes. )
Yes, IEC cables and plugs ARE rated at 10 amps but that is very, very conservative, especially since they rarely exceed 2mtrs in length.
I am sure I have said this before but when the bad KT88s went to "purple heaven" in a 200W amp they took out both HT fuses, the mains fuse AND the 13A in the plug.
Dave.
Apologies for the pedantry.
Kettle leads, should you still have one, should definitely have a 13A fuse.
Sorry!
of course
True, France e.g. has a spur system fused at 16 or 20 amps at the source (but 20A supplies are usually reserved for washing machines and other high current devices)
A spur system is wasteful of cable and of course lack of a plug fuse means you could have a fault only a bit over 16A with a flimsy cable and an eventual fire!
Dave.
