It reminds me a bit of a more angular Steinberger with a headstock:
You do realise the emo crowd are already going "meh, not black enough.."
I generally don't care what an instrument looks like.
Haven't watched the videos or anything yet so I apologise if this is obvious, but are the electronics new as well or is it just the old stuff in a new guitar shape? I like the idea of a variax for playing around with but I don't think I'd use it enough to justify having one.
Tunings not saving
selecting a les Paul/fender etc and getting a banjo or sitar etc instead
Variax mode not engaging so your stuck in standard guitar mode
Battery glitch issues that were software/hardware related
The list goes on. These JTV models went down on me several times whilst on stage
Those sound like:
On the fly tunings not saving - actuator switch not working or giving excessive 'bounce' command to the DSP confusing it and so defaulting to "do nothing"
Workbench tunings not saving - bad contacts in the VDI socket/bad cable. Its a multiplex connection, so Workbench needs to receive a checksum back from the guitar and back again before it formalises the save process. Any break in connectivity corrupts the checksum and the default is "do nothing"... sadly it wasn't clever enough to tell you that it hadn't completed.
Variax mode not engaging - the knob being pushed too far down the pot shaft meaning that when you push the 'switch' the knob hits the body before the switch actuates.
Model selector issues - bad switches and/or cracked solder joints on the three/four surface mounts on the breakout board. Very easy fix but irritating!
Either way - not great that you've had these and its unusual to have so many faults on one/two guitars. Did you send the guitar back/is it still under warranty? I'm nothing to do with Line6 these days but I'm sure the guys at the service centre in Milton Keynes would help you out.
The best one I owned was the old 500 but even that threw a fit every now and then
With all the JTV faults I spoke directly to line 6 support
They said they won't even bother repairing these issues and to go back to the store for a direct replacement which was what I did
The new 69 also went wrong after another year so that was then dead money
I then purchased 2 89's further down the line. One in black and one cherry. These both had major issues within 6 months. I did manage to get my money back from thomann after I forwarded all the correspondence from line 6.
To add that my father in law also purchased a 69 from Andersons when they reduced the prices. This also suffered some of the same issues within 2 weeks
I've owned lots of their gear over the years and never had a problem but the variax line holds little weight reliability wise
Some of the reduced price guitars were B-stock and customer returns that were sold off cheap - some stores chose not to make that clear in their advertising, I can't remember if Andertons did or didn't. Some of those were ancient and frankly nasty guitars... I wanted to send them back to the contract manufacturer for credit but I was voted down and they were sold off for less than the cost price. Frankly, I thought it hurt the brand... but I didn't make the financial decisions.
I'm sorry you had a bad experience, though. I'm not saying you are alone but the majority of experiences weren't that bad. Like I say, I'm nothing to do with them any more but I still kinda care...
At £5-600 I'd have one and just throw another guitar in the bin to keep to the 1-in-at-least-1-out rule.
Yes that's what I was told by two separate line 6 customer support reps. I assumed it wasn't financially worth repairing faulty circuit boards and easier to replace the whole thing.
