Knobs are as follows: Top left = boost volume. Top right = OD volume, Middle bottom is OD gain, Bottom right is tone
It kind of negates the need for the FZ2 on the end (which I'm using for a boost), but I like the pedal so just leaving it on the board for now.
I might actually end up with the FZ2 first in the chain, then I can get some nice fuzz tones. I want to get a Dynowriter thingy and label the pots (a la Cornish).
EDIT: Looking at the BYOC Overdrive 2 link you posted, maybe it is a Thorpy built version of those? Either way it's very very good.
Muff into tremolo into klone into rat clone into lunar module clone sounds so good to me right now.
Only playing this rig through headphones .. need to fire up that amp rather soonish
<a href="http://imgur.com/U0Ok3JY"><img src="http://i.imgur.com/U0Ok3JY.jpg" title="source: imgur.com" /></a>
http://i346.photobucket.com/albums/p437/Kylefarrell/My Pedals and Amps/4ABC3BDB-ECE8-4411-821C-72F5042E7496_zpsefwsdkcf.jpg
https://twitter.com/BBRdeathblues
https://www.reverbnation.com/badbloodrecovery
https://www.facebook.com/bad.blood.recovery/
http://i.imgur.com/uYBsAxu.jpg
How did the fuzz sound? to me it sounds HUGE - but I may be biased!!
EQ is just there if needed, but so far I haven't. The "Ultimate Tubescreamer" (one with tape on it) has switchable bass, so it helps remove any farty-ness. The Riot helps give a tight modern distortion into a clean sound.
Only thing I fancy is an SL Drive pedal, but right now I don't really need it.
Might put the Delay and EQ in the loop, but it would be a bit of a faff.
http://i1137.photobucket.com/albums/n505/dindude/IMG_1465_zpskyxymxqc.jpg
Latest incarnation of my little board.
http://i.imgur.com/aQrfXcK.jpg
Pickle Vibe arrived Friday, fitted to the board yesterday afternoon, gigged last night. Lovin' it
