SOLO of the Month #24 - Chat
Antique_GuitarsAntique_Guitars Frets: 1167
edited February 2017 in Making Music
This is the 24th SOLO of the Month (SotM) Challenge, being run by @Antique_Guitars and @TTony
We give you a new backing track to solo over every month. The backing track will be a maximum of 1.5mins long.
You download the track from our soundcloud page, record your solo over the top of it and then submit it to us.
Challenge #24 is now open, and remains open for submissions until 24th February.
Voting opens on the 25th of the month, and closes on the last day of the month when the winner will be announced.
Here is this months backing track (you can download it from soundcloud)
Specs: prepared by @paul_c2 ;;
Send your tracks to solos@theFB.co.uk
https://soundcloud.com/thefretboard/3rd-try-mix2?in=thefretboard/sets/solo-of-the-month-backing
The tracks will be uploaded to our SoundCloud account and saved in a playlist that will be linked below
https://soundcloud.com/thefretboard/sets/sotm-24-2017-02
Old Is Gold
  • submission mission complete
  • Sent in. Really trying to learn the slide, so went for that. not particularly good this month, but it was a good experiment. not my style of music either, so I found that tough - but in a good way. Thanks for the track @paul_c2 ;
  • Sent mine.
    Hopefully it got through because I got that strange non delivery message that happened last month.
    It's not a competition.
  • Rowby1Rowby1 Frets: 1283
    Mine's in.
  • Sent mine.
    I got that both months too, should be fine
  • Mine's sent. I thought I'd better send what I had rather than leaving it in the can like I do most months :) Nice backing again but a bit quick for me.
  • @Mudslide73 did you slow the track down?
    It sounds fractionally slower.
    Trading feedback info here
    My band, Red For Dissent
  • @Teetonetal @imalrightjack ;;
    Not intentionally, no. I've checked the Reaper project settings and it says 1.0 and plays back in the same tempo as I've submitted so I'm not sure what's happened.
  • @mudslide73 It shouldn't make any difference. I don't care :) I'd never have thought it had @Teetonetal mentioned it.
  • No it doesn't matter. Was just interested in how!
  • The thing is I don't normally submit a solo when I find it so difficult - I'm gutted tbh as I was struggling even at that tempo.
    It sounds the correct tempo on my system and I just checked by tapping the tempo into my metronome.
  • Wierd. Must be my ears. Start of a long slow decline perhaps!
    In Reaper there's a master project rate that can be changed (what I was alluding to above). There's also a pitch match setting that re-samples on the fly to play back the track (faster or slower) at the original pitch. You can then render the whole mix at the new tempo if you want. Those radio commercials with the impossibly fast T&Cs at the end are done this way I think.
    The thing is when I played mine back again I was convinced it did sound slower!
  • Just sent mine in.  I found a friends wah pedal that I didn't know I had.  Turns out using a wah is much harder than it looks!!!  Probably ought to give it back too!!
  • Got the usual failed message so hopefully everything is ok
  • Entered at just the last second.  Fnarr.
  • Fantastic solos for this one, alas I have had no time this month but will enjoy voting.
    Only a Fool Would Say That.
  • Entry closed
    Old Is Gold
