SOLD: Complete small PA - Phonic Powerpod/Peavey Messenger Pro 15s - £345
This is a compact 300W per channel stereo PA system that my rock band used on the infrequent occasions we didn’t play in a venue with its own PA. It’s 8-9 years old but lightly used and never thrashed - I’ve owned it from new. There are some slight wear marks in places, but nothing significant.
It hasn’t been used in anger for a couple of years and is unlikely to be for a while, hence the sale. In full working order and has no problem filling a room of 100+ people carrying the vocals clearly and easily above a 4-piece backline. Play interval music during breaks on an iPod. Makes a great practice space PA. We put the ‘monitor out’ send into powered floor wedges.
Collect in person only, I’m afraid. It’s too difficult to package properly and ship. It’s in Christchurch, Dorset.
£345 for everything listed below. I might split the mixer/amp from the rest if someone really wanted one part or the other.
Comprises:
1 x Phonic Powerpod 865 Plus mixer/amp.
- Dual 45 degree angular moulded cabinet
- 300W per channel / 4 ohms amplifier for main 1 & 2 or main / monitor (Bridge mono, 600W / 8 ohms)
- 24-bit digital stereo multi-effect processor with 16 programs
- Dual 7-band graphic equalizers with Feedback Detection Unit
- 8 balanced mic inputs through XLR jacks
- 10 line inputs through 1/4" jacks
- 2 Super Hi-Z inputs optimized for direct input of acoustic electric guitars and electric guitars or basses
- Wireless Mic module slot
- 3-band channel EQ (two channels with swept mid-range)
- Pad control on channels 1-6
- Monitor and effect sends on each input channel
- Stereo AUX input
- 48V phantom power
- Record output with trim control for recording level matching
- Handy mini-stereo I/O for MD, MP3 player/recorder, input with level control
- Vocal eliminator for karaoke application
- sPs for smoother high frequencies and enhanced low-end output
- Two built-in limiters
2 x Peavey Messenger Pro 15 passive speakers
- 15in woofer
- 1.75in tweeter (throat compression driver)
- 300W into 4 Ohms (continuous signal)
- 600W into 4 Ohms (varying programme)
- Top Hat socket on base
2 x 5m speaker cables
- Speakon connectors at both ends
2 x Speaker stands
- Adjustable with safety pin
- Fits securely into speaker base
https://dl.dropboxusercontent.com/u/23111633/IMG_1332.JPGhttps://dl.dropboxusercontent.com/u/23111633/IMG_1333.JPGhttps://dl.dropboxusercontent.com/u/23111633/IMG_1335.JPGhttps://dl.dropboxusercontent.com/u/23111633/IMG_1329.JPG
