Introducing the "Dual Foil" Humbucking Gold Foil.
MojopickupsMojopickups Frets: 314
I'll be adding these to the website soon, custom made in the UK covers.
These are a true Gold Foils but dual bobbin for humbucking, they'll also be available splittable so that you can switch to a single coil.
They are quite big 90x54x9mm.....they need to be to get both coils inside
I'll be making some minor tweaks byt will be ready very soon.
  • axisusaxisus Frets: 28341
    An interesting looking pickup!
  • Wow! Would be great in a strat with the swimming pool route
  • impmannimpmann Frets: 12678
    Oooh... that looks rather cool.
  • JalapenoJalapeno Frets: 6399
    Hubba hubba ! B)
    Feedback
  • WezVWezV Frets: 16782
    Any chance of a pic next  to the more usual suspects.  How does it compare in size to a wide range for instance?
  • @Mojopickups ;
    Are pole pieces under the cover or a rail/blade type underneath set for a particular string spacing?
  • AlegreeAlegree Frets: 665
    @Mojopickups ;
    They use blade shaped magnetic rubber stuff
  • MojopickupsMojopickups Frets: 314
    Cheers.  I must admit that has me very tempted.    I have a tele with a swimming pool route that it would fit into easy enough...
    @WezV here they are in a Jazzmaster to give you an idea of size, they fit in a standard Jazzmaster route.
    that does look awesome.   I have been going back and forth on the tele.  I want an unusual neck pickup for it...
    just slightly worried because a wide range manages to look even larger when put on a normal  tele plate - like this
    time for a  photoshop mockup I think
    edited March 2017
    you know, it might just work!
    @WezV I'm going to have to build a Tele now!
    Do you do anything unusual looking in a tele bridge pickup format?
    I am thinking purely aesthetically here as I am rather happy with the bridge pickup it already has (an older model BKP flat 50), but can't help thinking there would be something that looks a bit better.  I suppose gold foil tele bridge pickup would look OTT even if it was possible... but blade or stapletop (staples angled to follow the strings.. not much room for a coil??)  could look immense if it worked.
    Tonally, do you know how do these play with other pickups yet?   I don't mind a tonal mismatch, often I prefer it to a paired set, but I like to keep volume balance in the right ballpark if possible.
    I need a couple of mustang pickups too and should be in a position to order by the end of the week
  • earwighoneyearwighoney Frets: 3498
    For something of a smaller footprint, I can't recommend enough the Speedbump Marc made me I have in the neck of my guitar.  HB sized but is a bit GF coloured for tone.
    I'm thinking of going for the GF HB in the bridge, Hershey Bar in the neck for my Trohman Tele (when the funds allow!)
