GigRig Doubler with a different power supply?
BintyTwanger77BintyTwanger77 Frets: 2236
edited March 2017 in FX
I currently have a Strymon Ojai power supply, and all the outputs are isolated, running on 9V with max 500 mA current draw. If I wanted to power an 18V pedal (in this case the Dr Scientist The Elements, which can run at 18V), would I be able to use a GigRig Doubler with the Ojai, or would I have to use it with a GigRig power supply?
  • John_PJohn_P Frets: 2750
    I can't see any reason why I won't work - I assume the doubler uses a transformer to up the voltage so as long as the supply can cope I don't see a problem and the strymon has plenty of power.
  • keirkeir Frets: 137
    I used a Gigrig supanova with mine and it worked fine.
    Good deals with: handsomerick, majorscale, gassage, sticker, smudge_lad, anglian, edinfield99, thewiddler, thomfripp, notonlybutalso, JDE, chebellanga
  • BoromedicBoromedic Frets: 4883
    It'll be fine, I use one with a Cioks DC8 with no issues.
    My head said brake, but my heart cried never.
    is a Y cable not a cheaper option? (I.e. doubling up the 9V)
  • BintyTwanger77BintyTwanger77 Frets: 2236
    edited March 2017
    I need to use all 5 outputs, 3 of the pedals are powerful digital ones and the other is a compressor, so can't do any daisy chaining from the other outputs.
    Cheaper options for 9-18v include the Diago one and also there is an Xotic one around too.
    http://www.diago.co.uk/adaptors/18v.html
    http://www.hotroxuk.com/diago-ps08-18v-adapter-9v-to-18v.html
    P.s. Love the username!
    Thanks!
