Website || Feedback Thread || PayPal
sorted.
I reckon ES 8 as the only digital bit allows midi control and pre / post amp, so:
Cali 76 CD, Brothers, empress tremolo 2, Clusterflux, Wombtone, Spectre, Tonal recall Moog MF104m with a CM Headroom (FS-able dual settings) is about as close to perfectly all analogue as you will get.
Admittedly that doesn't stop me wanting a Babbage Engine.
If that doesn't speak volumes, I don't know what does. My point is, "happiness" isn't something we tend to settle with, even when we get everything we want.
Yep. It's also based on the assumption that analogue sounds better than digital, which may have been true(r) once*, but probably isn't any more.
*Having said that, I can think of a ton of pedals that use modern digital processing to emulate old, less hi-fi digital because people think it sounds better, or at least that it has "a sound" that you'd want, and can't get otherwise.
(not suggesting you *should* like them, just correcting in case anyone else wonders)
