Spalted Maple guitars...show 'em off,
  • KalimnaKalimna Frets: 1543
    As far as I know, the black lines in spalting occur when two competing fungal colonies interact. They are very much 'battle lines'.
    Beech produces some of the nicest spalting available, but is otherwise a fairly dull wood. I do have some rather nicely patterned spalted birch, but it has gone too far to do anything major with - the rot has turned the wood soft.
    One way to stabilise the softer spalting is to flood it with thin superglue. I imagine thin epoxy might work too, but I haven't tried that.
    Some nice guitars up above :)
    Adam
  • WezVWezV Frets: 16809
    In my experience, its not foolproof and might not penetrate as much as you expect.
    I did a carved top which I stabilised with the thinnest superglue before carving.  I used a few bottles until it stopped soaking in.  But when carving I found it had only hardened the top 2 mm and I was quickly back to soft wood.
      The second blackburst above used an acrylised spalted maple top - basically pressure treated with an acrylic resin and cured in a special oven to make it consistently hard all the way through
  • WhitecatWhitecat Frets: 5452
    axisus said:
    Whitecat said:
    Knaggs Severn Tier 2
    I'm really liking that! is it yours?
    Yes, thanks! :)
    Wez - Is there a way to use an acrylic resin for stabilising without specialist pressure treatment? Having done a little woodturning with spalted wood, I know what you mean about the sinkage being less than you might hope. I suppose one way to approach it (if using as a thinnish cap) might be to treat the underneath with cyano and then the top surface once near finish-carved.
    Adam
    Adam
    I don't know - Larry Davis (Gallery Hardwoods) used to do it and I had a few tops and fretboards from him, probably about 12 years ago and he was always talking about retiring back then.   The exchange rate made it very reasonable back then.
    @Skelf might know more on that front
  • skelfskelf Frets: 209
    Larry has retired, sort of. He still works with myself and one other builder that I know of in relation to the acrylic impregnated woods.
  • ChuckManualChuckManual Frets: 692
    timmysoft said:
    Gassage said:
    What actually causes spalting? Is it a fungal growth or something? Mineral staining?
    Treebola
    I'm sorry, but this pun deserves more praise than it's got!
    Not much of the gear, even less idea.
  • VoxmanVoxman Frets: 4738
    Sorry if this is going against the grain, and maybe I'm bark-ing mad, but am I the only one here who thinks this type of guitar wood and finish looks horrible, cheap and nasty?
    It can look like wet cardboard.  Which is what I think of when I see a lot of factory spalted guitars... but I still think the right bit can be pretty
