Decent speaker cables.
  • ICBMICBM Frets: 72531
    So there's no issue slapping a couple of decent plugs on some flex I've got laying around??
    None at all. The only thing that matters is the quality of the plugs and the soldering, as long as the cable is of at least adequate gauge.
  • SassafrasSassafras Frets: 30301
    I've often used cheap twin core mains flex and you couldn't tell the difference between that and Russ Andrews style cryogenically frozen, spun, directional irradiated platinum stranded cable that costs 20000 quid a centimetre.
    As ICBM says, quality plugs are the most important bit.
  • normula1normula1 Frets: 640
    My wife has a habit of going through irons like I do strings so I cut the cables off and use those with the slightly larger Neutrik plugs.
  • ICBM said:
    Tones said:
    I found this to be v good in use:
    http://www.thedenkeighley.co.uk/headtocab.html
    £70 for a 1m 1/4" speaker cable?!
    Click through, they're not even built well! Madness.
    I bought a fancy speaker cable for my HiFi once, I think I spent £60 in total for around 5m of cable which isn't really too much. The issue was that the solder joint on the speaker end disconnected and my amp exploded, like literally burst into flames.
    Now I use the same cable they use to power Lawn Mowers, and make sure I do the solder joints myself.
  • professorbenprofessorben Frets: 5105
    Does it not sound a bit flat??
  • kreggskreggs Frets: 64
    Stop it! You've  got me in creases =)
  • zepp76zepp76 Frets: 2534
    He's just letting off steam!
    Tomorrow will be a good day.
  • lentolento Frets: 117
    Once heard that Quad were exhibiting their new ELS 63's at a Hi Fi show and forgot to take along the speaker cables.
    They popped over to the local B & Q or wherever, and bought the orange Lawn Mower cable !
    Ahhh I thought he was getting hot under the collar.
  • simonksimonk Frets: 1467
    Can we get back to the pressing issue at hand please?!
    Keep your shirt on fella!!!
    I feel this thread is getting too heated.
  • the_jaffathe_jaffa Frets: 1801
    I'm a bit fed up of these laundry puns. You could say I'm ironing board
    Apparently  the cable is good for playing iron man though!
    I agree it's starting to fray at the edges.
    And looking a bit threadbare.
