PRS knobs....
HootsmonHootsmon Frets: 15987
edited April 2017 in Guitar
On the PRS custom 22 (2008)......the 3 regular round  knobs, what is the set up Folks?
tae be or not tae be
  • SporkySporky Frets: 28665
    Volume, tone, 5-way rotary pickup selector.
  • HootsmonHootsmon Frets: 15987
    Right Sporkers ,how about the 5 way?  :)
  • SonicScytheSonicScythe Frets: 59
    edited June 2017
    5reaction image LOL 0reaction image Wow! 2reaction image Wisdom
  • SassafrasSassafras Frets: 30306
    I thought this was about people who play guitars with fancy maple tops for a moment...
    What, Les Pauls?
    Five way rotary switch- full bridge, outer coils in parallel, inner coils in series, inner coils in parallel, full neck.  I think.
    edited June 2017
  • guitars4youguitars4you Frets: 14363
    effectively correct - I tend to break it down to humbucker bridge, split, humbucker both, split, humbucker neck - to make it easy ( others are not sure what outer coils in parallel mean) - even substitute split to Fender-esq
    It's never both humbuckers like a Les Paul though is it.
  • CollingsCollings Frets: 411
    It is indeed not. The two inner coils in series just sound like a louder version of the inner coils on parallel to me.
    Bummer, no twin HB PUP mix ala  les paul.....are they ( other coil mixes) nice usable sounds?
    sorry - you are correct - me typing without thinking - well spotted - still effectively HSHSH
  • Adam_MDAdam_MD Frets: 3420
    That's why I switched mine to a push/push with a  3 way toggle.  I missed both humbuckers together and the middle position on the rotary was always the one I liked least.
  • ICBMICBM Frets: 72598
    edited April 2017
    The five sounds are as follows:
    Full
    Thin and uninspiring
    Nasal and uninspiring
    Thin and slightly differently uninspiring
    Aggressive
    Does that help?
    Although I did think this was going to be about those horrible slippery 'lampshade' knobs they use now, instead of the nice normal round 'speed' knobs they used to...
    tis no biggie to mod it as so many folks have already done..the rotary can easily be replaced for a 3 way toggle switch like a LP...and a push/pull or push/push to get the split sounds if you want 'em.
  • grungebobgrungebob Frets: 3344
    but the 5 sounds on the rotary are superior to the 6 you get with push/pull in my opinion. well they may sound better now using the "prs" trick of the partial tap?
  • richardhomerrichardhomer Frets: 24849
    Sorry - thought it was a thread about Carlos Santana!
  • HalikusHalikus Frets: 59
    If someone could tell me how to wire up a guitar with a 3way+push/pull and still retain the same positions as the 5 way....
    I'm pretty certain it can't be done with the 5 way rotary (if it can I've not seen a diagram) - the 5 way blade has a different way of doing it, but obviously you can't interchange those 2 formats of switch - look inside at the 5 way rotary and you'll see it has many tags so allows for many functions - whereas a 3 way is the most simple
    I was thinking it was *actually* correct ;)
    I never really use the both 'buckers on option so thought it sounded useful.
