'Direct mounted' pick-ups - good, bad, indifferent?
VoxmanVoxman Frets: 4727
I've noticed that some guitars are advertised as having 'direct mounted' p/ups whereby these are screwed straight into the guitar body rather than using eg mounting rings.  Certain guitars/models eg Chapman, ESP, Wolfgang mount the p/ups in this way.
Allegedly pick-ups mounted in this fashion are supposed to be less sensitive to height adjustment changes thus making 'sweet spots' easier to find, and give a fuller more resonant tone.  The cynic in me is wondering if this is merely a cheaper way to mount pick-ups and if there's an element of marketing 'spin' here to turn a 'negative' into a 'positive'.
What are your thoughts guys?
  • stickyfiddlestickyfiddle Frets: 27193
    I'm sure it changes the way the pickup vibrates compared with one mounted on a ring or a guard, but I see no reason for the "sweet spot" thing - surely that's a function of magnetic fields, which won't change between the two cases.
  • WezVWezV Frets: 16767
    edited April 2017
    You will get a lot more of the bodies vibration fed into the pickup. Depending on wood it can sound richer, depending on the pickup it can be more microphonic.....  if you chuck a load of foam under there it's mainly lost again.  On true direct mount the pickup is solidly fixed to the body.... and that's often too much for many.
    no mojo here, just string vibration and electromagnetism... a vibrating pickup will provide a different signal to a static one.  A direct mount pickup will vibrate more than a spring/plastic mounted one
    1reaction image LOL 0reaction image Wow! 4reaction image Wisdom
  • ricorico Frets: 1220
    I think it looks 'unfinished'. Quite ugly in my opinion.
  • richardhomerrichardhomer Frets: 24848
    edited April 2017
    The most well-known 'direct-mount' pick-up is the neck pick-up on a vintage-style Tele. It's not possible to isolate all variables - but the modern arrangement (where the pick-up is suspended from the scratch plate) sounds softer to my ears.
    I'm prepared to believe there is some tonal difference - but I wouldn't see it as a 'selling point' as such.
  • VoxmanVoxman Frets: 4727
    Yup, that was my thought too. ;)
  • Jack_Jack_ Frets: 3175
    I much prefer the look, it's a lot cleaner in my eyes.
  • ICBMICBM Frets: 72574
    Agreed. And the pickup on a Les Paul Junior - which doesn't even have springs, it's hard-mounted.
    But as you say, there are other variables - the Junior sounds more aggressive than the bridge pickup on a Special, but the Special has the magnetic damping of the neck pickup and an altered neck joint with the pickup rout going through the tenon.
  • DanielsguitarsDanielsguitars Frets: 3299
    I did direct mount pickups on a strat style mostly because I don't want to cover up a nice piece of wood with a bloody great scratch plate
    I also think it suited my build
    Couldn't tell you if it sounds better or different, it was a bit more messing around getting the heights for the pickups to balance as this was the first one I'd done like that, I'd do another like it no problem
    www.danielsguitars.co.uk
    (formerly customkits)
  • Dave_McDave_Mc Frets: 2362
    The few I've tried/owned always felt a bit microphonic to me, as @WezV said.
  • stonevibestonevibe Frets: 7160
    I like direct mounted pickups and have  a few guitars which have them. Wouldn't say it looks 'unfinished' and to be honest some guitars looks fugly with pickup rings or pickguards anyway.
    My Peavey Wolfgang Special has direct mount humbuckers and it sounds really good for rock stuff, lots of sustain and plenty of 'sweet spots' on the guitar as a whole.
  • Dave_VaderDave_Vader Frets: 360
    Has anyone mentioned P90s yet?
    Ok.
    P90s
    There are cork sniffers on the les Paul forum that claim they can hear the difference when putting plastic tube over (or replacing) the pickup mounting springs.
    As usual you can debate this until the cows come home, but any appreciable distortion makes it a moot point and who can tell once the band start thrashing away beside you! P90s are typically direct mount.
  • RockerRocker Frets: 4992
    My Anderson has the pickups mounted on the guitar body. There might be foam between the guitar and the pickup plate, TBH I never checked. No need to, it is a great playing and sounding guitar..
    Nil Satis Nisi Optimum
    I agree about the tone thing, but I'd say that high gain would actually likely accentuate the microphonics of direct-mounting.
    If I remember correctly, Brian May direct mounted the pickups on the red special to increase the feedback he could get.
    I may be wrong.
  • Danny1969Danny1969 Frets: 10454
    EVH.s uses direct mounted PU's ...it does make a difference I think, I prefer it myself
  • HaychHaych Frets: 5682
    Would have to agree, for some reason I find the direct mount pups on a Charvel Pro Mod/San Dimas thingy much more attractive than when they use pickup rings.  Wish I hadn't sold mine now!
    Turns out there is an H in Haych! ~ Sporky
    Bit of trading feedback here.
    I think direct mounting EVH to my guitar would make a bigger difference :D
  • OilCityPickupsOilCityPickups Frets: 10642
    My own favorite method to body/direct mount is to use silicone tube over the screws, then a tiny foam pad if I need to change the tilt angle of the pickup.
  • ElwoodElwood Frets: 455
    edited April 2017
    Has anyone made a plate that screws into body and the pickup attaches to?
    Think of it as a flat metal bar with 4 screw holes in a line. The two middle ones are counter sunk and used to attach the bar into the body. The outer two are treaded and allow you to bolt the pickup in place (similar to the 9D connectors used on Serial cables). You could use a block of wood or coins to shim the pickup to the correct height.
    No too bothered about tonal effects. It would just be a more satisfying mounting method.
    It would also be better for people that regularly swap pups.
