It is very good, but in hindsight I probably should have spent the little bit more to get the Relfex before they went up in price stupidly.
And each output can be expression or an LFO. And the LFOs can be controlled by the expression pedal, or fixed, or synced to MIDI clock, and if they're synced to MIDI clock the expression pedal can control the clock division. And it has presets so you can make it do completely different things per patch.
If all you want is volume, wah and pitch shift then it's over the top, but the creative possibilities are enormous.
R.
Eqd Speaker Cranker clone
I've gone for a Source Audio Reflex - not all that much more than the Mission Engineering SP1-L6H.
R.
Ah, really? Wank. Is it not a separate switch output? I guess I should have done more research...
R.
R.
R.
