Advice needed about pedal board cases
ijontyijonty Frets: 32
edited March 2017 in FX
Hi all
I have a hand-made pedal board, and am struggling to find a case to fit it. The tricky thing is that because it's angled, the height is with the pedals attached is perhaps taller than normal boards.
The dimensions are w460mm x d310mm x 160mm.
Can anyone advise me about how I could get a reasonably priced hard or soft case to suit this size?
Here's some shots of the board in case that helps:
https://cl.ly/0B1Y1L1r2C2q
https://cl.ly/32431M2g361W
Cheers,
Jon
________________________________________________
Telecaster American Deluxe, Cornell Romany amp, without the talent to use them properly
  • thomasw88thomasw88 Frets: 2334
    most of the flight case companies will build to  spec - or you could just ask them if they have anything suitable. I think Castle cases do quite a high pedalboard case if you check their website.
  • ijontyijonty Frets: 32
    Thanks, will have a look...
    In the end, the best solution was suggested by @builttospill.
    The large size of this was perfect, and cheap too:
    http://www.clasohlson.com/uk/Instrument Case/Pr314142000
    case image
  • Looks awesome!
  • Excellent set up there! I'm forever changing my pedal order... using heavy duty velcro wasn't the best of ideas... I woke the kids up trying to prise the big box DDM from my board
    So, you lift everything out, or does the lid come off?
    Yeah, lift it all out. It's just to carry stuff around - it wouldn't actually work to play with it in the case.
