Gator 4L shock Proof Flightcase - £100 (As New condition)
ATA Molded PE Shock Rack w/ Rubber Shock Suspension; 4U- Lightweight Polyethylene Construction
- Independent Rubber Shock Absorbers at Each Corner
- 360 Degree Air Ventilation Around Equipment
- Threaded, Field Replaceable 7mm Zinc-Plated Steel Rack Rails
- Adjustable interior sliding support on each side of rack adjusts from to back and up and down for rear support of gear
- Comfortable recessed side handles and locking lids
- Heat-treated 10/32 rail bolts & washers included
- 200lb Weight Capacity
Color: Black
Handles: 2 Carry
Latches: 4 Twist
INTERIOR DIMENSIONS
Interior Length: 419 mm
Interior Width: 483 mm
Interior Height: 178 mm
