Rosewood neck - what to finish with?
Oil? varnish? wax? leave natural? What is the done thing?
and do guitarists put anything on Ebony fretboards for conditioning?
  • octatonicoctatonic Frets: 33851
    edited April 2017
    You can do a coat of tru-oil rubbed in with 0000 wire wool if you like.
    There is a lot of natural oil in rosewood- how oily is the neck?
    I would let that decide it for me.
    I put lemon oil on ebony boards.
  • WezVWezV Frets: 16812
    Barely anything.
    polishing it up with micro mesh works well.
     Rub with a bit of danish oil if needed, but rub most of it off straight away again.
    i would avoid heavier oils like tru-oil on rosewood.  But if you do use it the same rule applies.... buff it all straight off within minutes
  • axisusaxisus Frets: 28347
    edited April 2017
    I would say not particularly oily at all. I'd quite like to do something to it as I think it would look a bit better. I'd love it if I could get it a bit darker.
    Then oil will not hurt
    Thanks people!
  • randellarandella Frets: 4317
    edited April 2017
    You've probs already done it by now but another vote for a bit of truoil on the back and a wipe down with lemon oil on the board.
    It's easy to go overboard (sorry, bad pun) on the lemon oil and, contrary to expectation, it doesn't make your fingers smell nice either. Quick rub with kitchen towel fixes it though
    It darkens up the board beautifully too...
    Edit - apologies, thought we were talking about a maple neck with a rosewood board. As you were...
  • richalderandashrichalderandash Frets: 27
    edited April 2017
    I wouldn't use just Tru oil on rosewood.  I recently built a board with rosewood, and - because of the oils in rosewood - the Tru oil wouldn't absorb.  If you want that finish - and I can't blame you! - put a coat of sanding sealer on first.  This will stop any oils in the wood from interfering with the Tru Oil.
    alternatives are Danish Oil & Shellac. Different appearances but both have a very smooth, well-playing finish.
  • PVO_DavePVO_Dave Frets: 2380
    Finished mine with Eze oil and briwax, looks and feels amazing. Easy enough for me to do it too :)
    Nope, I've not even shaped the back yet! Just planning ahead.
  • KalimnaKalimna Frets: 1543
    The rosewood neck i made a couple of yeaes ago was finished with 3 light coats (as they always are) of tru-oil rubbed with ultrafine steel wool. No adherence issues at all, and a lovely satin finish to boot.
    Adam
