Peacekeeper - school me
monquixotemonquixote Frets: 17716
in FX tFB Trader
I have one of the majors finest incoming.
So peacekeeper owners how do you use yours?
Interested what pedals/amps/guitars you like it with.
«13
  • RandallFlaggRandallFlagg Frets: 13973
    I use mine to beat people who use the term "school me"
    27reaction image LOL 1reaction image Wow! 2reaction image Wisdom
  • hotpickupshotpickups Frets: 1823
    Ha ha I feel your pain @RandallFlagg ;
  • GulliverGulliver Frets: 850
    Plug it in
    Turn it on
    Fiddle with knobs
    4reaction image LOL 0reaction image Wow! 2reaction image Wisdom
  • monquixotemonquixote Frets: 17716
    Thanks I'm glad I asked
  • digitalkettledigitalkettle Frets: 3337
    Mine is after a Gunshot: low gain, volume hike for solos, mids pushed.
    I've taken two pedals off my board since the veteran. Can't see why I'd need them. Still fancy a peacekeeper though ;)
  • SquireJapanSquireJapan Frets: 721
    That's an old school schooling right there.
  • ennspekennspek Frets: 1626
    Boost, Low gain, always on pedal, works with any kind of amp. It's impossible to answer because it does so much really. Before other pedals, after other pedals etc etc. It's just so flexible.
    Sorry I realise this isn't much help.
  • hubobuloushubobulous Frets: 2352
    I use mine after the Warthog to turn a JTM45 crunch into a lead tone. I originally tried it with the PK going into the WH, but it's so much better after it. Both Thorpy and I were surprised and I grin each time I use it. On its own, it's also very versatile
  • Pete24vPete24v Frets: 235
    I use mine to add a bit of grit to my clean amp, and to push the Gunshot for solos.
  • rawk100rawk100 Frets: 1757
    Would a peacekeeper be suitable for tightening up/boosting a cranked amp for playing metal (bit like a tubescreamer)?
  • GassageGassage Frets: 31019
    edited May 2017
    OK; I have back to backed this with a lot of similar pedals- including a Cornish CC1.
    It has a clarity that's astonishing. Really open, strident, middy.
    Whenever I am searching for 'that overdriven but clean tone' I will go through the tube glitteratia in the rack, get frustrated and then try the PK and it's like wow.
    It's seen off CC1's, yellow side of KoT, Tube Drivers, TImmys....
    Utterly one of the best pedals I've ever tried. The only one I've not b2b'd it against is the Tim and I'd like to.
    One thing I've found, don't set the volume low and gain high- but that applies to any dirt pedal.
    It does a clean midboost brilliantly, it does crunch sublimely.
    It can do if you set it that way. Ridiculously versatile pedal.
    Blimey you guys are selling it to me now. Lol
  • Winny_PoohWinny_Pooh Frets: 7831
    edited May 2017
    How many can you fit on a pedaltrain nano?
    You can get 5 on a pt2 :)
    But can you lift it? ;)
    Thats not even in the top 3 heaviest pedal boards I've had!. G system on a pedal train must be the worst
    Cheeky little TS Mini sneaking in on the end there, trying to muscle up with the big boys
    25 LOLs, 1 WOW and 2 Wis and counting for that quip. Thank you luvvies.
