5 String Bass help needed
13»
  • prowlaprowla Frets: 4938
    mixolyd said:
    ICBM said:
    And you can always tune your bottom string down to D to play Stand By Me...
    Mind. Blown.
    Or, buy a Hipshot drop D tuner, flick the lever, play "Stand By Me", flick it up again and carry on...
    And if that's too pricey, then just tune the bottom-E string down to D - that's what folks did before Hipshot came along...
  • FunkfingersFunkfingers Frets: 14552
    DLM said:
    €2k is too much for a "basic" US Fender 4-string. Those prices are either too high.
    All musical equipment in the Irish Republic is subject to an extortionate mark-up.
    In the case of Fender, the further you get from their European distribution hub, the greater the overheads become. Various middlemen expect a cut. The government adds purchase tax. The customer's options are pay up or manage without.
  • DLMDLM Frets: 2513
    @Funkfingers How about buying online from Europe then? What's the Irish ceiling on tax-free EU imports?
    I do not know.
    What I can say, however, is that mail ordering will not help if the OP wishes to try before buying.
  • crunchmancrunchman Frets: 11463
    edited May 2017
    ICBM said:
    I have sometimes wondered about tuning my bass BEAD exactly for that reason. So still four .
    I've thought about this tuning as well.
    I did borrow a 5 string off of a friend for a while, and it just felt wrong.  G should be the third fret on the top (looking down at it, not pitch) string, but it's on the next string on a 5 string, which my brain thinks should be a C.
    If I was going to play 5 string then I would probably need to play it full time because moving between 4 and 5 is not easy.
    The other thing that I discovered is that my short fingers and the width of a 5 string neck don't work well together.
    I would like a low D, but almost all the music I like was recorded with a 4 string.  If it's good enough for my musical heroes it's good enough for me.
  • DefaultMDefaultM Frets: 7365
    I use a 5 string in a pink floyd cover band, because then for the songs in D like another brick and run like hell I don't have to detune.
    So it's not needed but sometimes it's convenient anyway.
  • RockerRocker Frets: 4989
    I have decided against a 5 string bass in favour of a Fender Precision. The 5 string bass has a wide fretboard, which I don't like, and having tried out a Precision, the quality of the notes won me over. USA built basses are uber expensive here in Ireland, so it will most likely be a MIM bass. Used will bring the purchase price down so it is a question of waiting until a suitable bass comes on the market. Thanks for all your contributions guys, they helped me a lot.
    Nil Satis Nisi Optimum
    I played a Roger Waters signature precision a bit ago and I really liked it. I thought it sounded better than my stingray 5, but they're probably trying to do different things.
    Hardly mutually exclusive. https://www.thomann.de/de/fender_am_pro_p_bass_v_rw_3ts.htm
    <Facepalm> Somebody has not read this Discussion from the beginning.
    It is a pity that this board does not allow a Discussion starter to close it once the question has been answered.
