https://www.amazon.co.uk/d/DIY-Tools/Kärcher-2-880-990-0-karcher-O-Ring/B007Y5HL6U
Offset "(Emp) - a little heavy on the hyperbole."
there is a set for £12-14 that is definitely for my model, but contains loads of other sizes too
Using my micrometer, it looks to be 8mm externally, and about 1.5mm thickness, but that is the damaged one
https://simplybearings.co.uk/shop/Seals-O-Ring-Seals-NITRILE-O-Rings/c19_4501_4705/index.html
https://www.polymax.co.uk/o-rings/rubber-viton-oring/ - so I didn't want to pay £12 for a few
I'm just wondering what the accurate size is for these, since the one I'm measuring is a bit mangled
The old one is in bits in my garage so you are welcome to have any parts from it that you want..including hoses and wands.
PM me if interested
including 20 that fit perfectly, and the pressure hose now works again
Cheers chaps
