The main issue I can think of is ram, as noted 8gb isn't a lot these days if you're using big sample libraries. IIRC you can't upgrade ram on an Air, not sure on the pro
I use a 13-inch Air and have never had the fan kick in during recording, only when I'm absolutely caning the CPU at mixdown.
That spec should be fine, in the remote case that he exceeded the Ram then a swap file on an SSD shouldn't cause any problems I would have thought.
Dual core is fine to a point but I'll eventually over when doing complex mixes.
