Best method for sanding?
So im looking to prep a body (removing a wudtone finish and then home spraying). Would doing it by hand (a block and sandpaper) or woild buying a hand sander be better?
  • paulnb57paulnb57 Frets: 3065
    Id go with a combination of both, get the woodtone off with something mechanical work through the grits and finish by hand in the curves and along the grain....
  • octatonicoctatonic Frets: 33836
    Usually you use both.
    There will be places where an electric sander won't be able to reach so you use different sized blocks, or even just folded up a piece of paper.
    I often use a piece of 6mm dowel that I use some adhesive sandpaper (called 'Stick-it) to as well.
    Be extremely careful on curves- it is very easy to fuck up the profile of the roundover and once it goes you will really struggle to get it back.
  • JalapenoJalapeno Frets: 6398
    Sanding off paint/varnish can take an eternity, be warned. The old finish gums up sandpaper really quickly - you can really get through sheets of the stuff ......
    Heat / chemical might be quicker and more effective if you want to take it back to the wood.
    Feedback
  • JetfireJetfire Frets: 1696
    Andy wudtone suggested a flap wheel to do the curves etc
    I wouldnt use a flap wheel, much too aggressive and too high speed in my opinion
    Yup, I agree.
    Perhaps make some radiused sanding blocks that you could glue some adhesive sandpaper to.
    Hmm its only a basic layer but i may have a go later.
  • WezVWezV Frets: 16773
    I used a flap wheel on my very first squier strat.  First modding project.   It probably still has a flapwheel shaped contour inside the cutaway.
    i tend to avoid the corners altogether.... right to the last point once I have reached about 180g everywhere else.   Past that you are onto finish sanding rather than stripping
  • GSPBASSESGSPBASSES Frets: 2351
    Wudtone finish  is really thin, I've had to remove it a few times from guitars, couple of passes with  120  sandpaper and it's gone .  After that go through the grades of sandpaper job done.
    This tallies with my experience. I stripped my jazzmaster and used a circular sander with 120 grit, made very short work of it, then used some foam (thin foam) backed sandpaper for the curves (that, incidentally, you gave to me - don't suppose you remember what it's called?).
