SOLD - BAD CAT 15R 1X12", flight cased. £1050 !!
jimkehoejimkehoe Frets: 210
edited June 2017 in Amps £
SOLD
I have gone back to a Princeton reverb and  am now offering this beautiful beast for someone else's pleasure.
Bought recently from @miserneil. It is far too much and too good for what I need right now. ( spare room noodling).
Solid quality flight case included as well as double footswitch for channel & reverb switching.
Grab a bargain - Straight sale £1050.
Collection from Surrey.
http://i48.photobucket.com/albums/f249/jimkehoe1/BAD CAT/fullsizeoutput_35b0_zps5gjzzcxr.jpeg
http://i48.photobucket.com/albums/f249/jimkehoe1/BAD CAT/fullsizeoutput_35b3_zpsej6a5wom.jpeg
http://i48.photobucket.com/albums/f249/jimkehoe1/BAD CAT/fullsizeoutput_35b2_zpsaf6cajng.jpeg
http://i48.photobucket.com/albums/f249/jimkehoe1/BAD CAT/fullsizeoutput_35b4_zpsdnkj8mvm.jpeg
The real deal - Beautiful Class A EL84 CHIME AND GRIND.
All hand wired. This would cost £2500 new.
Complete with fitted cover and foot switch for reverb and channel switching.
Two entirely separate channels one 12AX7 and one EF86.
Both with their own tone stack and adjustment.
Each channel also has separate foot switchable reverb and separate Master volumes which can individually be switched out if required.
Built solidly and to top engineering specs but manageable weight wise unlike it's bigger Bad Cat/Matchless version.
The Black Cat 15R combo features all the tone of the 30w version, but at a more manageable volume. Just like the 30-watt older brother, the Black Cat 15 is dripping in three dimensional cleans. Push up the gain and go from soft chiming break- up, on through to thick complex gain. Running in Class A, this rig is oozing with harmonics.
Channel one is built on a 12AX7 treble, bass and cut tone stack providing the warm and sweet tone with just the right amount of mid push to cut through the mix. Switch over to channel two and experience the more aggressive, hi-fi sounding EF86 preamp. More chime, more grunt. The EF86 can be switched between the five-way tone selector or the bass and treble tone stack. The tone selector offers a selection of five-tone caps and enables you to adjust the amount of low end content to fit the guitar or situation. Global cut and separate master volumes for each channel can be switched in or out.
Superb unblemished condition. Grab a bargain.
