My HP desktop computer is acting strangely these times. When powered up, it stays stuck displaying the 'Blue' HP screen. Power down and up and it then goes through the bootup procedure perfectly. This happens every time and is consistent. Another thing to note is that it takes several minutes to complete the bootup routines [when the hard disk activity light finally extinguishes]. Running Windows 10.
I suspect a virus has 'done something' to cause this.
Options are to take the machine to one of the computer repair shops in town. Get them to install a SS hard disk for the OS?
Replace the existing hard disk with a new faster bigger one.
The PC itself is 8 or 9 years old. I upped the RAM a few years ago but any speed gains from this seem to have gone down the tubes. The machine is probably way over its best before date so I might be better off scrapping it and buying a new floor box. What do you guys think I should do? Requirements are the usual suspects, email, internet browsing, music server, MS Word and similar programs. No heavy apps like CAD or gaming. No recording activities or music editing/manipulation either. Thanks.
Nil Satis Nisi Optimum
Just because you're paranoid, don't mean they're not after youhttp://www.pcworld.co.uk/gbuk/computing/desktop-pcs/desktop-pcs/hp-slimline-411-a000na-desktop-pc-10158387-pdt.html
Offset "(Emp) - a little heavy on the hyperbole."
Both cut-and-paste, but this one worked...
Step 1: Back everything up.
Step 2: Spend £30 - £40 and get a decent drive, or spend £100+ and go SSD.
I disagree with @Legionreturns - if it's a relatively high-spec 2010 machine, it's still perfectly usable. Hell, I've recorded albums with machines older than that.
Just because you're paranoid, don't mean they're not after youNil Satis Nisi Optimum
For instance on my machine, when it applies an update and reboots it seem to forget it has a boot drive
but restart manually and it is all OK.
Have you ever added a drive in the past or taken one out/replaced?
If so go through the bios, sometimes old drives seem to hang around and can't be deleted, in which case update the BIOS to the latest version, that seem to clear out old clutter.
@Myranda, I have been told that I need an i5 [or at the very least an i3] processor with 8 Gbytes RAM and a large hard drive. An additional SS drive would speed things up too.
Is this over speccing for a home computer? Running the usual apps and operating as a music server. I do now want a laptop, a mini tower or similar will replace what is there right now. I have a 60 cm monitor which is good and does the job.
Thanks.
If you have a LOT of tabs open in browsers, want to encode video, record music with a lot of tracks run Virtual Machines, play computer games then you'll need more...
Personally I'd build a PC with enough horsepower that I need to consider cooling the room especially... But we might use our PCs for different things ;-)
All with a single support call and patch management part of the service.
All delivered and working within 45 days.
Sorted
Yeah, I didn't see any graphics cards in that list...
@Rocker for basic use stuff this looks like it'd deliver and have a bit in reserve for those times you want more tabs open or whatever.
https://m.johnlewis.com/asus-vivopc-k20cd-desktop-pc-intel-core-i3-8gb-ram-2tb/p/2961360
