P90 issues
Evening all,
So ive just re-wired a Les Paul with P90's
Setup includes;
500k pots
0.022 caps
"50s" style wiring
The neck sounds beautiful - but the bridge sounds like an ice pick. Very harsh indeed.
Any ideas?
Change the capacitor on bridge controls to a 0.047? Change pot to 250k/300k?
thanks
  • AlegreeAlegree Frets: 665
    The answer is always my Murky Horizon set.
    Jokes aside I'd go for the 250k pot first.
    Or a magnet swap to A2.
  • TeyeplayerTeyeplayer Frets: 3266
    No joking Alex...it's the truth!
  • FunkfingersFunkfingers Frets: 14570
    How close to the strings are the P90s adjusted?
    Also, have you changed or repositioned either of the bar magnets in the bridge/Treble position pickup?
  • ICBMICBM Frets: 72580
    Turn the tone control down a bit - that's effectively the same as replacing the pot with a 250K.
    Changing the cap value won't have a noticeable effect when the control is up full.
    Replacing the *volume* control with a 250K might be more effective...
    Perhaps, now would be a good time to establish the make and model of the P90 pickups under discussion?
