42 is NOT the meaning of life!
  • 57Deluxe57Deluxe Frets: 7348
    Additional properties of the number 42 include:
    • It is the third primary pseudoperfect number.[2]
    • It is a Catalan number.[3] Consequently, 42 is the number of noncrossing partitions of a set of five elements, the number of triangulations of a heptagon, the number of rooted ordered binary trees with six leaves, the number of ways in which five pairs of nested parentheses can be arranged, etc.
    • It is an alternating sign matrix number, that is, the number of 4-by-4 alternating sign matrices.
    • It is the number of partitions of 10—the number of ways of expressing 10 as a sum of positive integers (note a different sense of partition from that above).
    The 3 × 3 × 3 magic cube with rows summing to 42.
    • Given 27 same-size cubes whose nominal values progress from 1 to 27, a 3 × 3 × 3 magic cube can be constructed such that every row, column, and corridor, and every diagonal passing through the center, is composed of 3 numbers whose sum of values is 42.
    • It is the third pentadecagonal number.[4] It is a meandric number and an open meandric number.
    • 42 is the only known value that is the number of sets of four distinct positive integers abcd, each less than the value itself, such that ab − cdac − bd, and ad − bc are each multiples of the value. Whether there are other values remains an open question.[5]
    • 42 is a (2,6)-perfect number (super-multiperfect), as σ2(n) = σ(σ(n)) = 6n.[6]
    • 42 is the resulting number of the original Smith number (4937775 = 3 × 5 × 5 × 65837): Both the sum of its digits (4 + 9 + 3 + 7 + 7 + 7 + 5) and the sum of the digits in its prime factorization (3 + 5 + 5 + (6 + 5 + 8 + 3 + 7)) result in 42.
    • The dimension of the Borel subalgebra in the exceptional Lie algebra e6 is 42.
    • 42 is the largest number n such that there exist positive integers pqr with 1 = 1/n + 1/p + 1/q + 1/r
    • 42 is the smallest number k such that for every Riemann surface C, #Aut(C) ≤ k deg(KC) = k(2g − 2) (Hurwitz's automorphisms theorem)
    • 42 is a perfect score on the USA Math Olympiad (USAMO)[7] and International Mathematical Olympiad (IMO).[8]
    • 42 is the maximum of core points awarded in International Baccalaureate Diploma Programme.
    • 42 is the sum of the first 6 positive even numbers.
    <Vintage BOSS Upgrades>
