Washburn Rs10v re-refinish
SargeSarge Frets: 2429
edited July 2017 in Making & Modding
I bought this from @JohnnyPlectrum last year or the year before, and it had had a terrible refinish, and the frets were worn and uneven, it has been sitting in the bedroom unplayed since purchase.
https://imgur.com/6zyNx0W
So finally I got the other projects done which gave me time to do this
https://imgur.com/ya1DzBR
Finished with Rustins Plastic Coating, frets levelled and crowned etc, much much nicer in looks, feel and playability.
  • SargeSarge Frets: 2429
    Oh and the colours are courtesy of Keda Dyes, really the most vibrant colours I've come across so far.
  • lysanderlysander Frets: 574
    Impressive finish. How did you apply the rustins?
  • paulnb57paulnb57 Frets: 3073
    Wow, difficult to believe its the same guitar! Good effort!
    Thanks, it was applied with a standard varnish brush, one coat every 3 hours with a light flatting after every two or so.
    Thanks bud!
  • WezVWezV Frets: 16778
    That's the way I used to do it before I stayed doing more spraying.
    Looks good!
    Thanks @WezV ;
    This is the 2nd time I've used it now, really happy with both results.
    I cheated with the electrics a bit, it's got a prs 5 way selector and it's set up to be a Custom 24, the switch looks like spaghetti junction and I wasn't confident of resoldering it correctly/ neatly.... So in the cavity I cut the pickup leads and just resoldered those with heat shrink tubing inside and out ;)
    Positions are
    Position 1: Bridge humbuckerPosition 2: Bridge humbucker with neck singlecoilPosition 3: Bridge and neck humbuckersPosition 4: Neck singlecoil with bridge singlecoilPosition 5: Neck humbucker
