The Difficult Second Build - Finished with video
    Beautiful job.  Fast work, too!
  • TimberGTimberG Frets: 50
    thanks @Andyjr1515 I started this about 5 weeks ago just been saving up the images for the build thread. It will probably slow up a little now as I have the finishing to doe and then I am making the neck from scratch.
    Had a slow weekend in the workshop however roughed out the maple neck blank and finger board and have to say the grain on the maple finger board looks really nice
    http://i.imgur.com/FD0YFJv.jpg
    and I have also marked out the neck and truss rod cavity
    http://i.imgur.com/EIKk4WC.jpg
    Thats it for now looking to route the truss rod this week so will update as and when
    Bit of an update stated the neck and first off is the truss rod channel
    https://imgur.com/a/Xuizn
    and then hen roughed out the shape of the neck, headstock has been a tricky one to design as I wanted something different
    https://i.imgur.com/bVz8AYo.jpg
    On to the fretboard here you can see me slotting the frets I use a GMC luthier tools fret slot jig
    https://i.imgur.com/fU1yrqE.jpg
    glueing the the neck and the fretboard together excuse the state of the work shop
    https://i.imgur.com/Z1Y6NFO.jpg
    next is to trim down the fretboard on the neck and then start the carve on the back
    thanks for looking
    Its been a while since my last update in May (how time flies)
    Neck has now been removed from its clamps and the excess finger board material trimmed off
    http://i.imgur.com/w6YosYb.jpg
    And then the neck profile started using a saw rasp (amazing piece of Kit!)
    http://i.imgur.com/JFuAyaK.jpg
    Next was sanding and scraping the neck profile (no pictures of this)
    Installed the abalone dot markers and medium jumbo frets and then gave the fret ends a little dress up prior to proper set up and levelling etc.
    http://i.imgur.com/9ldOvlr.jpg
    I couldn't resist the temptation to see what the Schaller machine heads would look like, so I had to do a test fit and they look stunning
    http://i.imgur.com/QYjp1b2.jpg
    http://i.imgur.com/iPOmZWc.jpg
    Now next was probably the most difficult for me, originally I was going to oil this however I have not clear lacquered a guitar before so thought why not try my hand at it. GULP!
    So first coats are using a Nitro clear coat from Rothko and Frost diluted down to 30% thinners, I did 4 coats and then have let it dry for a week before block sanding down ( I had to due to a couple of runs in the finish).
    http://i.imgur.com/oLxfrjY.jpg
    http://i.imgur.com/XeE8890.jpg
    Block sanded the body and neck using 600grit paper and then again used a 30% diluted nitro mix (just to clarify 70ml of clear coat to 30ml thinner) again using an anti bloom thinners. again repeated this for 4 lighter coats this time (learnt from my over exuberance before)
    And then Leave - For Two weeks (longest two weeks ever)
    Block sanded the body first using 800 grit, then 1000grit, then 1500grit and finally 2500grit papers ( probably didn't need to go through that many but oh well)
    Then used G3 cutting compound to polish the body up
    This is the result and I am really happy for my first real spray job.
    http://i.imgur.com/SMPnSkC.jpg
    http://i.imgur.com/hSXDXND.jpg
    and the back as well.
    http://i.imgur.com/S2KJaPR.jpg
    Next up is the neck which I have not done yet that for this weekends workshop time. I am on the home stretch now and cant wait to start putting it all together.
    Thanks for looking
  • paulnb57paulnb57 Frets: 3073
    edited July 2017
    Bloody hell thats nice, my only dislike is the headstock shape, but thats just my preference, stunning work amd a great finish, crack a beer!
    Beautiful job :). Excellent finish, first time or not!
    Thanks @paulnb57 the headstock is always hard to do correct and I am trying to get my own mark
    looks better in person
    @Andyjr1515 are you kidding your build knocks socks off mine thanks for the comment really pleased with the finish
    I think it looks great, @TimberG :)  I never expected that purpleheart to hold its colour like that - and it's not an easy wood to work with.  Respect, mate, respect ;)
  • VinylfanVinylfan Frets: 33
    That is a very inspiring build indeed.  Love the colour of the purple heart wood.
  • JalapenoJalapeno Frets: 6399
    Looking ruddy marvellous so far !
    Feedback
    Thanks all for the comments - bit of a lull in progress however should be updating with some progress in the next couple of days
  • Only just found this thread.
    Wow... really nice work. Looks great.
    Thanks @Strat_a_tat_tat ;
    Next instalment coming up
    Right then its been a busy 3 weeks and have only just got back in the workshop with the main reason to finish it
    After the body had been polished i decided to leave the neck as painted as it came out rather well. the neck was then fitted to the body
    http://i.imgur.com/y17STz0.jpg
    then was installing the 3D scholar bridge with the earth wire under the saddle
    http://i.imgur.com/gmTX8mJ.jpg
    Next was Graphite paint the pick up cavities and the electronics and the back of the control cavity plate
    http://i.imgur.com/9azXwyy.jpg
    Next installing the Bareknuckle Blue note P90 pickups in the cavity, i used a pair of old hum bucker springs to give the adjustment.
    http://i.imgur.com/zRsZX7R.jpg
    Installed the Schaller Devinci Machine heads
    http://i.imgur.com/lRjQVdS.jpg
    Next up the electrics, this has consisted of CTS 500K pots for both Tone and Volume, Sprague 0.022uf orange drop caps, normal 3 way toggle switch, i thought keep it simple. Oh used cloth wire as well.
    http://i.imgur.com/ni3qNjQ.jpg
    Tested the electrics and everything worked as it should (its a first for me as I usually wire something up wrong)
    Strung the guitar up and cut the nut slots using the Crimson guitars nut slotting tools.
    Then onto string height which was adjusted to around 1.8mm at the 17th fret ( a starting point) and then checked intonation and then locked the bridge off.
    Plugged it in and Wow!...I will put some video clips up but have done the arty party shots...i am really really pleased.
    http://i.imgur.com/1WDJvve.jpg
    http://i.imgur.com/GTxLNpR.jpg
    http://i.imgur.com/xnoQrFp.jpg
    http://i.imgur.com/QIsHtSg.jpg
    http://i.imgur.com/l9yz5PL.jpg
    http://i.imgur.com/sMjxSfJ.jpg
    Phew!
    Now for the next Build...Lol!
    Just as a pointed this one will be for sale if your interested please PM me.
  • I really love the body appointments - not sure about the headstock design personally but you can't argue how lovely it's come out.
  • BigMonkaBigMonka Frets: 1783
    Looks great! Nice one @TimberG ;
    The purpleheart is cool, but IMO that back is really lovely, particularly the way you've brought out the figuring with a smattering of black dye
    Thanks both @BigMonka and @WilliamAyerst for the positive comments
    the he ash had a really nice grain so made up some grain fill and added the dye at that stage
    I am really pleased with the Schaller hardware as you would expect its high quality and went together well.
    head stock shape is a little different I am probably going to change it slightly for the next build albeit I am going to have to sell this one to fund though
    edited August 2017
    Selection of Sound clips as performed by friend of mine there are loads on the TimberGuitars youtube chanel.
    https://youtu.be/iSjLe6TvDq0
    Bridge pickup selector with clean Amp which is a 40w Fender Blues deluxe reissue
    https://youtu.be/nxg5zOeQQmk
    Middle pickup selector Clean
    https://youtu.be/yJvijkZVuLM
    will post the crunch channels tomorrow
