Relief on both is ironing board - at .005 (0.13mm) !
Set it so it's easy to play, but if I dig in hard with a pick it gets really grindy but doesn't fart out and have no low end like if there wasn't enough tension or clearance. It's got a tight low B (.130 through body) and is probably the loudest solid body bass I've played acoustically. It is also marginally sub 9lb IIRC. Man I wish I could find a guitar this good!
NS NXT EUB about half an inch
The necks on those are supposed to be the same as the 64 I thought?
It wasn't the MIM - it was the 74 P I measured
What a twat
The classic neck is slim front to back but very wide. It's weird, as a 7.5" radius it feels pretty flat due to the width.
Once I got used to it, I just find narrower necks too cramped.
